Garden Logo
Mike Marsocci Posted on Sep 22, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Fuel line routing diagram for echo pb 201 - Echo Garden
roeb
Level 3:
  • Echo Master 819 Answers
  • Posted on Mar 30, 2019
roeb
Echo Master
Level 3:
Answers
819
Questions
0
Helped
385253
Points
2343
The 90 degree fitting gets line with filter in tank.
Fuel line routing diagram for echo pb 201 - 9bf0f8cd-6133-4312-9a77-6b795f4755ed-c5swlujwikltdnfhjbeihqyi-1-0.png
5 Related Answers
Anonymous
  • 3600 Answers
  • Posted on Jun 21, 2009
SOURCE: Weedeater XT 85T trimmer fuel lines rotted
it's in the fuel tank it goes from the carburator into the fuel tank and replace the fuel filter while you have the tank off.
Anonymous
  • Posted on Jun 22, 2009
SOURCE: Need diagram for fuel lines on craftsman chainsaw
There is two sizes of line. I see the large one goes to the large port on the primer button and then to the fuel tank. The small one goes from the primer button to the carb. The problem is there are two hose connections on the carb. I believe one is a vent, but I am not sure what one it is. I have a 36cc 2-cycle model 358.352161
Anonymous
  • 3 Answers
  • Posted on Jul 14, 2009
SOURCE: need a diagram to route fuel lines on a carb
my polaris outlaw 500 sarted cuting out last ride could not ecerate past 1/4 throtle and was back fireing so went to fix and wont run at all i have spark, plug is wet, changed fuel, seems to have compresion, when it turns over it tries to fire at times more like a hickup almost stops the sarter and a puff of smoke out the carb. im about to tare it down any ideas whats wrong ? bike was hard to start but ran ran perfect killed raptors with ease. bike was bored and built by some shop before i owned using ktm sleave and piston ? motor says nicols 520. didt over heat or make noises. have tried cleaning carb, jeting no luck please help
Anonymous
  • Posted on Aug 21, 2009
SOURCE: echo pb-260l won't rev up under load. like it is
blown moter from bad gas mixture
rycgl
Roy Cagle
  • 1545 Answers
  • Posted on Jul 22, 2011
SOURCE: What is the fuel/oil mixture
Sometimes, the fuel ratio is stamped on the fuel cap. Your ratio is 50:1. Echo specifies using 89 (mid-grade ) octane Here is a chart that tells you how much oil you need in a gallon of gas...Just 1/2 it for a half-gallon mix. A copy of your manual is also here.
http://support.mtdproducts.com/app/answers/detail/a_id/347/~/two-cycle-engine-fuel%3Aoil-mixture-chart
http://www.echo-usa.com/getattachment/624aee9f-103c-416c-ae9b-55fb42dd94af/PB250es1112_010410_1.pdf
1helpful
Echo PB-251. Wont run full speed,changed ,plug,filters
I'm 99.9% sure it's the fuel line. The ethnoll in gas really shrinks the oem fuel lines
Echo pb 251 leaf blower leaks oil
You need to check your gas line and the primer ball itself and make sure you don't have a split in the lines or in the ball, also check the fuel filter in the gas line to ensure it is not plugged up.
Starts dies
Fuel lines could be collapsing from being soft, mush from ethanol in gas, possibly you have wrong carb kit, or something put together wrong, fuel lines reversed, double check everything then make sure you exhaust screen is not plugged, cause this will do same thing.
3helpful
What kind of fuel do you put into an Echo PB201 Leaf Blower?
The blower is a 2 cycle, so you run an oil and gas mixture. Here is the link for the owners manual.
http://www.echotool.ru/files/50_17_21-21G-00.PDF
My echo pb-201 hand held leaf blower starts and runs for about 2 minutes then begins to sputter and stop. Sometimes I can get it to work for about 4 minutes but then stops.
may be a clogged fuel filter or bad fuel lines check to see if they are real soft if so replace it they are fine the may need a carb kit
Jan 13, 2011 • Echo Garden
1helpful
What 2 stroke fuel ratio do i use for the es 2400 leaf blower
50 to 1 don't use outboard 2 stroke oil. Use good oil echo, still, Husq ect.
Top Echo Garden Experts
john h
Ngoro
vince
Are you an Echo Garden Expert? Answer questions, earn points and help others
