SOURCE: Toshiba (Model : 36A43) - volume goes down automatically
I am having same problem on 32 inch same problem. After playing with board with no results,I tried front buttons and found that if I held the power button in ever so slighItly as not to turn it off, it fixed problem which is the micro on/off switch, I removed the switch and used the remote and everything is back to normal, I am about to insall a used micro switch after I finish typing this but I am sure this will clear up volume problen and menu going crazy problem if not I will just leave micro switch out and use the remote, and I will get back to this board only if that micro switch still causes the problem, so if I don't post in next hour the problem is fixed and I'm more than glad to help.
SOURCE: volume automatically goes to maximum on TCL TV
The volume (+) button on the TV is stuck or soiled if the volume automatically increases when the TV is turned on. To find out:
To find it out further:
Warning: Beware of electric shock.Please do not proceed if you do not have the skill to do the following.
To do a hard reset of the TV, unplug it and let it sit for 2 hours or long enough to completely drain the internal voltages.
SOURCE: Dell 32 inch LCD Tv volume and menue problems
I had the same problem with my tv.No sound! I finally figured it out. It was the speaker wires! Once I changed them to a slightly stronger speaker wire, it worked great! I have sound to my tv and I haven't had any problems since then.
SOURCE: The volume goes up automatically, then after a few
Most of the time it is the touch button assembly on the tv. The Volume down touch button switch is sticking.
I hope this helps,
Skyassoc
