SOURCE: E1 error code.
The pressure foot was up instead of down when I tried to run the machine without sewing something.
highly annoying issue error code E1. After hours
of fan operation, the error code E1 will appear on the seven segment
LED temperature display. This error code is intended as a reminder for
the user to clean the air filter. However, because the procedure
outlined in the user manual does not clear this error code as
indicated, and the appliance has a nonvolatile memory that cannot be
reset by simply unplugging it, the user of the appliance will become
mightily frustrated, standing in potentially sweltering heat watching
the appliance repeatedly shut down in the midst of operation with the
"E1" display flashing.
Believe it or not, that is what it does: if you unplug it to remove the
"E1" code from the display, and plug it back in and re-start it, it
will simply run for anywhere from a few minutes to a few hours, and
then merrily shut down again with the same flashing "E1" code.
So you will come home to a hot bedroom, living room, etc. unexpectedly,
and you will NOT be amused, as I was not.
Many people at this point, having put the manual under the canary or
some such, will simply return the unit and never buy another Sharp air
conditioner. But for the tech-savvy and search-adept, I offer the
following procedure to clear the nefarious E1 indication, and obtain
1. Power down the air conditioner using the "power" button on the front
panel.
2. Unplug the air conditioner from the wall socket.
3. Hold the front panel "power" button down and plug the air
conditioner in. Continue to hold the power button down as the machine
goes through a brief test sequence (fan & compressor each come on
briefly, etc). There is a "beep" sound at the end of the test sequence,
and the machine will be off. At this point, you can release the power
button.
4. Unplug the air conditioner.
5. Plug the air conditioner back in.
6. Congratulations! You should now be able to operate the air
conditioner normally for another 720 hours, but only if you followed
the instructions above EXACTLY.
_____________________________________________________
Was this solution helpful? Show your Appreciation by rating it.
Thanks for using fixya support..You have a wonderful day
SOURCE: Kelvinator kd14ss
This is a common problem with this machine. Per the manual E4 indicates that the machine is overloaded but this is incorrect. The machines has actually become water logged due to a design fault whereby some water is allowed to pool at the bottom of the machine rather being efficiently drained. Note that the area where the water pools is not rust resistant. To temporarily overcome the E4 error, tilt your machine backwards and the excess water will drain out the back corners. Remember to put some towels down to avoid a big mop up operation afterwards. I live in a coastal area so drain the machine this way once a month and then open up the back of the machine (don't do this if still under warrantee) to dry it out completely to minimise the rust.
SOURCE: error codes E1 to E5
E1: tape end detection LED open
E2: front loading motor lock
E3: loading motor lock
E4: cylinder motor lock
E5: reel motor lock
These are from a Panasonic AG-7500 service manual.
