Watches Logo
R
Robert Garrison Posted on Sep 10, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have an Automatic Mechanical mens watch that stops while on my wrist. It does not start when wound. I reset the time and feel sharp resistance when I turn the stem and the watch begins.
This happens daily since I purchased the watch 3 years ago. How can I have it repaired.
Arturs Kalnins
Level 3:
  • Master 2,338 Answers
  • Posted on Oct 05, 2018
Arturs Kalnins
Master
Level 3:
Answers
2338
Questions
9
Helped
1814253
Points
13579
Only qualified watchmaker will be able to repair it.
5 Related Answers
tidzamon
  • Posted on Jun 11, 2008
SOURCE: Pulsar Men's analog wrist watch - how to set day and date
Pull crown out to 1st position....Turning one way will alter the date and turning the other way will alter the day.
piman314
  • 4 Answers
  • Posted on Aug 04, 2008
SOURCE: Eddie Bauer watch.
these watches are waterproof so the stem is screwed down to seal out water. Try turning the stem to unscrew it somewhat , then pull out the stem to set.
Anonymous
  • Posted on Feb 26, 2009
SOURCE: automatic watch not working
I would suggest you do the following........
Pull the bezel out to the first notch then wind the it back and forth for a couple of minutes then that should be it.
How do i know this. I have had a Roadster for a 6 years and just found this out yesterday.
Enjoy the watch.
rgds
escapement
Arturs Kalnins
  • 2338 Answers
  • Posted on Jan 07, 2010
SOURCE: starting a stopped automatic wrist watch
Unscrew the crown and wind it, then screw it back and twist/spin your watch. If this does not restart it going, then there is mechanical problem in movement and you will need watchmakers help.
Anonymous
  • Posted on Mar 08, 2010
SOURCE: tag heuer link automatic
exact same problem, no one seems to know
I have had my accutron automatic vx-200 for about 4 years and has worked flawlessly until now . The watch keeps stopping , I move the hands manually with movement of the crown and will work for a few hours...
It could be that it needs cleaning. (When a watch is described as "automatic", it means that it is a mechanical spring driven type which needs to be worn constantly to keep it wound up; I assume that yours is one of these.)
Most makers recommend regular servicing at intervals of 2-3 years and as your is older than this, then perhaps it is time for a trip to their nearest service center.
Go to bulova.com to find your local service center.
I recently bought an invicata 8926A. It looks great, but I'm having some trouble winding it. When I wind it by moving it round and round for a few seconds, it runs for a while. But when i rest my...
This is certainly not normal. I had an automatic watch and because I wore it daily, I was unaware that is need any special treatment.
Automatic watches usually run for 2-3 days before stopping (if fully wound) and thrive on being used. My automatic watch was unsatisfactory when I bought it (new but very cheap) and I had it cleaned and it gave years of excellent service after that- perhaps that is your problem. I suggest that you contact their service center for advice.
If your watch is new then you should register it on their web site (go to http://www.invictawatch.com/invicta/services) and send it to them for repair.
If it is out of warranty, then you will see a price list on the above page (this is very unusual!) which will give you an indication of what you may have to pay to get it fixed.
How do you get started to wind a BMW watch. There is no resistance when I wind the crown. There does nt seem to be any plastic or anything in the way. I ve set the date successfully. Its a BMW Chrono...
mcdevito75 here, BMW watch, nice watch, Actually there are 2 ways to start winding an automatic or self wind watch. Since you feel no resistance in the winder (crown) which if you did, would mean the automatic mechanism is attached by gear to the mainspring and winding the crown (stem) would start the winding process. Without any resistance winding the crown, your automatic mechanism is free-lance as a way of saying, in your watch which simply means your BMW watch winds solely on wrist / arm motion. First, make sure you hear the automatic mechanism moveing inside the watch when you move the watch in almost any direction, now simply hold the watch in your hand and with a rocking motion, say from 12--to 6 rock your hand back and forth for about 30 seconds. You can also make circular motions with the watch in your hand for 30 seconds, any motion that will cause the automatic movement in your watch to move will, start the winding process. After you see you watch has started, simply wear your watch to keep it wound.
1helpful
Emporio armani 4211
mcdevito75 here, There are 2 ways to wind your Armani Emporio watch, I'm figureing it"s an automatic watch, on some automatics you can start an initial ticking by winding the stem in any direction, if when you wind the stem you feel any resistance then this is the type of automatic watch you Start with about 20--30 winds of the watch. If on the other hand when winding the stem feels very loose and free, no resistance at all, then this is the type of automatic that relize on pure wrist and arm motion to start ticking, simply hold the watch in your hand and make small circle motions, or rocking motion, you should detect something moveing inside the watch, this is the winding counter balncer it's normal, rock or circle the watch for approx. 30 seconds to get it started. In both cases, after the watch starts, the motion of your wrist / arm keeps it wound as you wear it.
WILL RUN A SHORT TIME THEN STOP
mcdevito75 here, I would imagine your Rolex is an automatic, not all Rolexes are. After 2 days not running at all your Rolex needs a very good start not just putting it on and that"s it. Sorry to say!, I would ask you to do this, With your watch close to your ear I would like you to wind the watch, listen closely, if you haer a clicking or a drag sound you know you have to give about 20 winds to your watch before you put it on, after the 20 winds the automatic takes over. If the stem just spins and no sound, Click or drag, then your rolex is fully automatic, after you put it on you"ll have to ttwist your wrist back and forth to get the automatic moveing to wind your watch somewhat. Twist your wrist back and forth maybe 20--30 times, this way your watch has an initial wind and as you wear it the winding continues with the motion of your wrist, after it"s wound pretty good if it stops and goes, have the watch serviced.
1helpful
Do Carrera automatic watch need a battery to run? because it stop me alot that why it just run for a few mins and stop forever until i move again
Automatic watches are mechanical (spring driven) and they are wound by the gentle swinging of the arm as you walk.
If yours has stopped, then it needs to re-wound by swinging it side to side (keeping the watch face level).
You will need to do this for some time (as many as 300 times, according to one maker).
When fully would the watch should run for about 3 days if not worn.
These watches thrive on use!
1helpful
Juts got the watch, wound it, worked then stoped, wound dead
These watches are self winding (mechanical spring), so need to be worn (or gently oscillated) to wind them up.
The catalogue for this watch says it should run for 72 hours when fully wound.
Depending on when the watch was made, it could be that it needs a clean.
Try wearing it for a few days to see if it keeps going.
Second hand stopped moving
If the hour and minute hands have also stopped, then the watch needs a new battery (if it is electric), or needs to be wound (if it is mechanical or automatic-mechanical).
If the hour and minute hands are still functioning and telling the correct time, then the second hand has become loose and needs to be re-attached. A watch repair shop can do this for you and it should not cost much.
1helpful
WATCH RUNNING TOO FAST BUT NOT THE SAME IN SAME INTERVALS
i think it has prob with its balancer.. anyway.. in this world there is no constant time,, n,n
1helpful
2answers
Automatic Watch Stops
There can be hundereds of causes why your watch isn't working properly, so, I'll not name them.
One is clear- without help of skilled watchmaker your watch will NEVER work properly.
NOTE: It may sound very strange, but mechanical watches do NOT like to be left without job.
Next time you decide to leave mechanical watch aside for long time- do not forget to wind it up once in a 2-3 days even if you are not wearing it.
This will help to prolong watch movements life and keep timekeeping steady and accurate.
Regards
Arthur
Top Sharp Watches Experts
john h
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you a Sharp Watch Expert? Answer questions, earn points and help others
