Cars & Trucks Logo
Orland Kydd Posted on Sep 01, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I am not getting any speed and power from my Nissan caravan non turbo zd30 diesel engine and it is just smoking when I press the gas
sherlywang
Level 3:
Master:
  • Master 428 Answers
  • Posted on Sep 19, 2018
sherlywang
Master
Level 3:
Master:
Answers
428
Questions
0
Helped
198585
Points
1063
Generator set will occasionally encounter generator failure in the process of use thatCummins generator setis not generating electricity. What is the cause of it? And what to do about it? In fact, there are a lot of reasons that Cummins generator set is not generating electricity. The following is compiled by Jiangsu Starlight Electricity Equipment Co.,Ltd to summarize the main reasons for generator not to generate electricity and the treatment methods.
5 Related Answers
Anonymous
  • 16 Answers
  • Posted on Feb 16, 2009
SOURCE: Power lacking
Blowing smoke when starting is not a problem this accours on all diesel engines
Remmik
Marco Avila
  • 58 Answers
  • Posted on Feb 17, 2009
SOURCE: 1990 300zx non-turbo coupe 5 speed
Old post but I would like to state that white smoke and white vapor are two different thing and blue smoke is sometimes so ligh it looks white but does act like heavy smoke. Evanescence of water vapor looks a lot like smoke but dissipates a lot quicker but in mass quantities can look like smoke (yes..I been dying to use that word ever since I heard of the band Evanescence lol). Transmission fluid can be sucked into the engine via a bad shift modulator both that has no bearing here (just FYI). In either case you would be fouling out spark plugs due to oil or water saturation and causing unburned fuel to be expelled.
Anonymous
  • Posted on Feb 27, 2009
SOURCE: nissan 300zx starts smoking when reaches tempture
trust me its one of the turbos if you take it out for a spin get the turbos working there will be no smoke leave it ticking over for 2-3 mins and the smoke will start if this is the case it is one of the turbos i had it with a new pair
Anonymous
  • Posted on Jul 17, 2009
SOURCE: Toyota prado 2LTE EFI loosing speed uphill auto trans
cylinder head
Anonymous
  • 63 Answers
  • Posted on Sep 05, 2009
SOURCE: smoke is coming from the dipstick, 6.5L turbo diesel
Sounds like you have a clogged PCV valve thats the valve that lets the gases that get into the crankcase be rerouted back into the intake. It's silver about two inches and is usually in a rubber fitting in the valve cover and will have a hose on the other end. it's no tools installation just pull the hose off pull it out and replace with a new one. thats the first thing i'd do - 10 mins and 10 bucks should do it
1helpful
2answers
I have a 1993 TD27 Nissan Atlas / Cabstar. How to stop the black smoke?
TD as in Turbo Diesel? They all tend from smoke a bit under acceleration.
White smoke is steam
Blue smoke is oil
Black smoke is rich mixture (in a gas / petrol vehicle)
1helpful
2answers
What's your question?nissan caravan zd30 tdd diesel hardstating when cold change prima and heater plugs .what could the problem
cranking speed to slow--cannot generate enough compression heat to ignite fuel
faulty injector tips ---squirting and not atomizing--have an accredited diesel specialist shop recon the injectors
worn engine---compression pressure too low -- have a compression test done
if common rail diesel ---fuel pressure too low to work the injectors properly-- have an accredited diesel special shop test the pump pressure -- should be around 22.000 to 25.000 psi
Where can i find a pump injector spare part of isuzu zd30 small in nairobi
no year state
zd30 is that not Nissan?
what car, is a zd30
wow country, stated, like 3rd time in 1,000,000 post,
you are savvy poster...
this is usa forum and our stores down sell zd30 parts
you need to shop in Nairobi. (or near)
my guess, is go to any Nissan dealer?
Diesel engine.
my guess is your car is.... right (its a wiki page)
  • Patrol - Chassis Code Y61
  • Caravan - Chassis Code E25 and VWE25
  • Urvan - Chassis Code E25
  • Homy - Chassis Code E25
  • Elgrand - Chassis Code E50, E51
  • Terrano - Chassis Code R50
  • Terrano - Chassis Code R20 (Europe only)
  • Atleon
Nissan navara 2002 twin cab diesel zd30 malfunction light comes on randomly
NISSAN NAVARA questions and answers
www.roadtestreports.co.uk/vans/nissan/navara/qanda/
Results 1 - 40 of 322 - Ask and answer questions on a variety of NISSAN NAVARAmodels. Help and advice ... Have a Navarra Rally Raid 2004 double cab pick up. ... Navara V6 2011 - loss of power & engine management light on. .... ZD30 I have changed the diesel filters after noticing that it's jerking when I'm on full throttle.
Nissan Patrol GR Y61 ZD30 starting problem - YouTube
? 1:23
https://www.youtube.com/watch?v=JxHKfYDCgFQ
Jan 16, 2013 - Uploaded by sspyropoul
After replacing the diesel filter seals and water trap i had no problem .But you ... They still glow for like 15 ...Missing: twin ‎cab ‎randomly
Nissan D22 Navara receives YD25 2.5-litre diesel
www.themotorreport.com.au/.../nissan-re-power-their-d22-navara-range
Jan 31, 2008 - Nissan's popular Navara D22 workhorse range has been ... On top of the 4x4 DX single cab's equipment, the dual cab ST-R adds .... the yd25 engine have a overheating problem, so how comes nissan is ... I believe it is a ZD30 engine. .... with no problems except a cracked injector line (pretty random fault).
My E25 zd30 dessile engine caravan is projected black smoke when I start and also when am driving. What can be the problem.?
its normal for a diesel to project black smoke but only from the exhaust pipe not the engine itself
Nissan caravan zd30 turbo producing blue smoke continuously
That might be a result of the head gasket going out. When that happens, antifreeze leaks out of the exhaust pipe. You should go and bring your car to a shop before major damage occurs.
Twin turbo 80 horse power deutz Diesel engine blows black smoke under load
Diesel engines smoke when under a heavy load. Unlike a gas engines, a diesel engine uses fuel that is more like an oil.Smoking is a good indication the fuel is not completly burning because of loaded engine spee. White smoke indicates the fuel is not ignitingefficiently. Truck, boats, tanks abd anything else using diesel fuel will smoke when it gets more fuel than it can use.. Easing up on the throttle will lessen the smoke but not eliminate.. Of coarse if the demand is lessened by applying less loadyhe fuel consumption drops.Not to worry as long as the smoke doesn't attract the EPA.
I got white smoke, changed head and head gasket, intake gasket looked bad. My question is: can a bad intake gasket cause the white smoke?
Not on a Gas engine, but diesel engine yes.
Diesel engine white smoke means leaking head, intake, or your turbo is not working.
Gas engine leaking intake would only cause rough idle, no power, etc,,,,
1helpful
2answers
1999 nissan terrano diesel turbo is lacking power , brand new fuel pump and comp chip installed and has run like **** since, has been put through comp diagnosis but no fault showing,(is very slow 2 pickup...
Possibly the "Mass airflow sensor". I had a similar problem, basically the car behaved like it didn't have a turbo and was really slow. Unfortunately the Mass airflow sensor is expensive, about AU$800. Only failed once several years ago. Hope this helps.
Top Nissan Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Arnie Burke
Arnie Burke
Are you a Nissan Expert? Answer questions, earn points and help others
