Kitchen Appliances - Others Logo
j
jane Posted on Aug 14, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I need the rotisserie kit for the T031
Hoping I can find a replacement rotisserie as the original is mia and I do not want to have to purchase an entire oven.
esbpgen
Level 2:
Habit-Forming:
Cheetah:
An expert who has answered 20 or more questions within one hour.
  • Expert 55 Answers
  • Posted on Mar 25, 2019
esbpgen
Expert
Level 2:
Habit-Forming:
Cheetah:
Answers
55
Questions
Helped
20358
Points
103
2 Related Answers
Anonymous
  • 1478 Answers
  • Posted on Sep 13, 2010
SOURCE: When I use the oven
The element to your oven can be replaced because they are not repairable, i will advice you check either ebay.com or amazon.com to buy a new element.
Take care.
Anonymous
  • 3 Answers
  • Posted on Jan 09, 2011
SOURCE: I need the owners manual for my Euo-pro convection
Here's the link: http://bmc.brandsmartusa.com/ProductData/ProductFiles/24747_europro_TO31_om.pdf
It took me forever to find it so I might as well share it! Hope it helps!
I just bought the Brinkman, and I am trying to figure out how to use the Rosterria. Can you help me?
Since a Rotisserie is an optional item for your model grill. I assume you have purchased one that is approved to be used on your model Brinkmann Grill Smoker. If not, I recommend that you Do Not use it. If it was approved, read and follow the directions that came with it regarding installation, setup and preparing to use the rotisserie.
The Rotisserie can only be used when you are not grilling anything else on the grill. Remove the grill grates directly in front of the rear infrared Rotisserie Burner. If you Don't, they will be in the way. In their place, you are going to use an aluminum pan (like a pie pan), as a drip pan for whatever you're cooking on the Rotisserie.Place that on top of the burner's flame tamers. Make sure the rotisserie motor is in place and you have electric power to it. Test the rotisserie spit, by inserting it into the motor's spit holder. If you have a Counter Balance, attach that near handle on the spit shaft just below the handle. If your rotisserie is missing the counter balance, you can not use the rotisserie.
Remove the rotisserie spit and place whatever you're planning to cook on it, following the directions that came with rotisserie kit. Make sure the spit forks are tightly embedded in the meat, whole chicken, etc. If a whole chicken, tie the legs together like a Thanksgiving Turkey around the spit..
Light the Rotisserie Burner and close the hood of the grill. Allow the temperature to reach a minimum of 250 degrees F, before opening the hood and installing the food loaded rotisserie spit.
Be careful, as the interior of the grill will be hot. Install the spit as you did earlier. Make sure it fits into both sides of the grill's hood correctly.
Turn the Rotisserie Motor ON and watch as the food turns. If it turns and then sort of bumps, when the spit turns around, adjust the counter balance to stop this. It should turn smoothly. Once all tha is completed, close the hood and allow the food to cook for whatever time, you would cook it in a kitchen oven. Rotisserie cooking is like smoking food. It's a low (temp) and slow (time) process. But, the flavor rewards are GREAT. Only check the food occasionally. The more you open the hood to peek, the longer it will take to cook. Each time you peek, add 10 minutes to the cooking time.
All of this, was sort of a thumbnail sketch of rotissering food. Search the web for recipes and techniques. You'll be amazed at what's out there.
Hope this helped you. Please let me know and Happy Grilling!!
2helpful
2answers
Which is the right rotisserie for the Brinkman 8534 Gas Grill? Where can I purchase it and how much does it cost?
You can find and purchase the rotisserie on Brinkmann's website. Click on the Accessories tab and then enter the correct model number for you grill.
http://www.brinkmann.net/home.aspx
May 14, 2011 • Grilling
Where can I purchase a (timer control knob) for george foreman rotisserie GR82 . I live in South Carolina. This is the (second) knob that has broken. Can't remember where I got a replacement knob before....
Replacement parts for the GR82 are available online from the following site:
http://www.directpartsandproducts.com/other-gr82-c-61_171_1017_1959_2097.html
If you do not see the part you need, suggest you contact this supplier at 800-738-0245 or via their webform to see if they are able to source for you.
How do i install the rotisserie on my grill..it is a pro series 8534...there are no pre-drilled holes and there is no way of closing the lid on the pit while it is cooking,,there is a slot cut out on the...
Buy the Brinkmann Universal Rotisserie Kit model #812-7102-S for $49.95. It uses 2 screws to attach a bracket to the existing tapped holes in the grill. It was that easy! I purchased my grill and the Rotisserie at Home Depot.
I have a brinkmann 8534 gas grill and i need to know how to put a rotisserie on it
Apr 12, 2011 • Garden
How to install original factory fog lightson ford escpae xls 2010 I purchase the original fog lights butcanot find the harness or connectors. Do I need to purchase another harness?
hi when you purchased these they should have come with a wiring kit supplied, if not then you will have to go to ford and ask them for the wiring kit for them, on most replacement fog lights not ford made come complete with wiring included...hope this helps
5helpful
2answers
Looking for owner manual for Farberware Millennium FSR 150 Rotisserie.
All the original Farberware "Open Hearth" Broiler, Rotisserie and Shish Kebab manuals (except the FSR 150) are available for download at http://openhearth.info . The FSR 150 is a composite of the earlier 450 455N 455ND spare parts. I have seen the manual for the FSR 150. It does not include any recipes.
Pali Mia crib
I just bought this crib on Craig's list and the ad said it converts to both a day bed and toddler bed, however I didn't have any instructions so found the Pali website and requested an instruction manual for this bed - and they indicated it converts only to a toddler bed, but you have to have purchased the conversion kit, which is also avaiable on their website.
So I would recommend going to the pali website and requesting the manual ! Hope that helps.
Top Kitchen Appliances - Others Experts
Paul Carew
vince
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
