I searched using https://www.google.com but did not find an exact match for the model oven your provided.
Although the following free manual has a similar model number, but is not exactly the same, it also has phone numbers and contact information for you to request a manual directly from the manufacturer.
https://theelectricdiscounter.blob.core.windows.net/images/kitchen/cooking-appliance/baumatic/bs65ms/bs65ms_manual.pdf
SOURCE: No manual
The light bulb is the oven light.
The snowflake with 3 raindrops is Defrost Mode (fan runs with no heat to reduce defrost time)
The 2 lines up top & down bottom is Traditional Cooking (heat from top & bottom elements)
The big circle with a fan is the Fan forced Oven
The small line at top only is the Grill Mode
The larger line at top only is the Double Grill Mode
The line up top with the fan underneath is Double Grill with Fan mode
The line on the bottom with fan on top uses the lower element with the fan for delicate dishes
The manual can be found on the Baumatic website - www.baumatic.com.au - select your product which takes you into another page & you will see on the left hand side a link to "View User Manual"
SOURCE: Fan Oven blows Fuse over 175 Celcius -Baumatic BT2760SS
Hi, I was cooking and my oven jut went off, looked in fuse mains box and had tripped. So put back on and now the fan works but no heat...Can you give me some idea what it mite be.
SOURCE: Baumatic built in oven (B600) product manual
I have a Baumatic P650SS oven. To adjust the timer volume, wait until it is beeping and then press the minus button and it will adjust through 3 sound levels. Release the minus button and the sound level of the audio signal will be set.
SOURCE: Chef regency oven with "HELP" flashing on panel. Have no manual
Usually means that the time needs to be set. Press Clock Set then use the up and down button to set correct time, Then press Manual button.
