Http://manuals.frigidaire.com/prodinfo_pdf/Edison/2020266a0180en.pdf
Here is the manual. You can view it or print it or download it for free from Frigidaire.
First, I'm not a Frigidaire tech.
* Check your warranty. Call for service.
* Contact (note Live Chat link); https://www.frigidaire.com/Search-Results/?q=dehumidifier
*** The following is for information only ***
* Note that this filter is a "wash - Reuse" and is probably considered a "Part" and not a consumable.
* Filter (check if this will fit); https://www.amazon.com/Frigidaire-5304487154-Dehumidifier-Filter-Unit/dp/B00PU1V4M2/ref=sr_1_1?s=home-garden&ie=UTF8&qid=1531339454&sr=1-1&keywords=frigidaire+fad704dwd+filter&dpID=61e1c6OA6UL&preST=_SX300_QL70_&dpSrc=srch
* Review; https://www.youtube.com/watch?v=BbwIEU3zlG8
* Correcting "Bucket Full" Error; https://www.youtube.com/watch?v=UzGnUG3r8dU
* Review (includes using a hose drain); https://www.youtube.com/watch?v=aAKN--TgQRI
* If your missing this filter then contact the local Frigidare or Appliance store for a replacement.
* Final; check your warranty. The filter may be covered.
Aloha, ukeboy57
SOURCE: I need a manual for the Kenmore #54701
Here is a link for the manual. You can download it and save it or print it.
http://www.managemyhome.com/mmh/lis_pdf/OWNM/L0406271.pdf
Hope this helps, it's from www.managemyhome.com
Maryanne
SOURCE: I have a Kenmore 580.53701300 dehumidifier (70
Jim,
I have this dehumidifier and the owner's and parts manuals to go with it.
I will scan them and email them to you.
Hope this helps!
Jamie
SOURCE: Frigidaire 70-pint dehumidifier won't work after winter
No reset button on the compressor... but this tip may give you some clues as to what is or is not happening..
Dehumidifier is running but no water is in bucket
http://www.fixya.com/support/r4662409-dehumidifier_running_but_no_water_in
heatman101
SOURCE: How do I empty my frigidaire 70-pint dehumidifier?
Here is a tip that I wrote to help people with just that dehumidifier problem..
Dehumidifier Problem It shows Bucket Full
http://www.fixya.com/support/r4688381-dehumidifier_problem_shows_bucket_full
heatman101
SOURCE: Frigidaire 50 pint dehumidifier freezing up and
Dehumidifiers freezing up can be causes by a few different problems.
Here is a tip that I wrote to help people with the freezing dehumidifier problem....
Dehumidifier is Freezing up and not working
http://www.fixya.com/support/r4662033-dehumidifier_freezing_up_not_working
heatman101
Hello lynn crisp, thank you for your post!
From what you have explained regarding your Frigidaire dehumidifier it sounds like the sensor or control panel has become faulty. I would recommend resetting your dehumidifier and you can do that by unplugging the power cord for ten minutes. Is your dehumidifier under warranty? If so, you may want to reach out to the manufacturer for a resolution to the problem. I hope this information is helpful. -Matt
I appreciate your post, Lee Silvey!
I understand that your Frigidaire dehumidifier, FDL70S1, will only work in continuous mode. Sounds like you could have a possible issue with the sensor or control panel. Are you under warranty? I would advise you to speak with your manufacturer to see if any further resolution can be provided. -Matt
