Cell Phones Logo
Blutooth is not working in my nokia 6233 - Nokia Cell Phones
1 Related Answer
Anonymous
  • 75 Answers
  • Posted on May 06, 2010
SOURCE: i just purchase Nokia BH-104 Bluetooth - through
First of all you should check the blue tooth setting in your mobile.see it.is it hidden or show to all set it up to show to all devices
Nokia 6233 PTT key doesn't make contact when i press it, why?
Take it apart, clean the contacts with switch cleaner. Check the back of the switch for a badly soldered dry joint.
https://en.wikipedia.org/wiki/Nokia_6233
Manual
NOKIA 6233 USER MANUAL Pdf Download ' ManualsLib
https://www.manualslib.com > manual > Nokia-6233
View and Download Nokia 6233 user manual online. Nokia Cell ... Cell Phone Nokia 6233 RM-145 Service Manual ... To make the call, press the PTT key.
It isn't a known issue, only your phone has this problem
https://www.google.com/search?q=Nokia+6233+PTT+key+doesn%27t+make+contact
Nokia 6233 is asking restriction code?
Hi, You can get the restriction code for a Nokia 6233 from www.superunlockcodes.com/nokia-6233/rs16wp9/ at affordable cost.
UNLOCKING STEPS FOR NOKIA 6233
1 - Switch on your Nokia 6233 without any sim card.
2 - Don't bother as to what is displayed on your Nokia 6233.
3 - Compose #pw+CODE+1#.
4 - The Nokia 6233 would then display the message "SIM Restriction Off" and will be unlocked!
Note :For Nokia 6233 mobile phones locked to the network Fido or Rogers in Canada follow these instructions :
3 - Compose #pw+CODE+7#.
The letter p appears if you press the button star(*) three times quickly
The letter w appears if you press the button star(*) four times quickly
The symbol + appears if you press the button star(*) two times quickly
The CODE you need to enter is the unique unlock code for your Nokia 6233
2helpful
Unlock code for nokia 6233
Hi, You can get the unlock code for a Nokia 6233 from www.wickedunlock.com/nokia-6233/rs11wp9/ at affordable cost.
Here are the steps for unlocking a Nokia 6233,
My 6233 blutooth not open
Hi i'm Basti!
You can setup bluetooth thru settings or application folder. You can configure it the way you would like it to work or connect. Please update me on what you would like to set it up with so I can give you the step by step instruction.
Cheers!
17helpful
2answers
Bluetooth not working on mobile nokia 6233
nokia 6233 bluetooth always on when i tried to switch off phone restart please tell me the solution on my email [email protected] plz bhai
Nokia 6233 Keypad NOT WORKING!!!
change keypad and use k750i see the keypad socket on up side and do some changes their
Faulty Sony Ericsson Blutooth
Well i also have a z530i and my screen broke . my bluetooth hasnt done that and i dont have a problem wiht my nokia 6233 or my n95. but i suggest you look on your infared settings and then turn it off IF it is on . then go back onto bluetooth or go on your shortcuts ( bottom left button ) and click bluetooth . if this doesnt work , just take it to a shop and ask for there suggestion. Hope i helped
Top Nokia Cell Phones Experts
Kolbrun...
Muhammad Irshad...
Muhammad Irshad...
