This is because this microphone has an
XLR audio connector for output.
YOU CAN'T USE THIS CONNECTOR FOR THE USB PORT since the
XLR is an audio type connector while
USB is a data type connector. You might use a cable with
XLR female at one end and 3.5mm jack like
this one with mono jack at the end (not stereo as the amazon's link) and connect this cable at the microphone and at the sound card of your computer. The quality with this solution won't be very good, it depends on your audio card. A better solution is to use
XLR-to-USB-Signal-Adapter/dp/B001PPXFAG/ref=sr_1_16?ie=UTF8&qid=1290885531&sr=8-16">this adaptor or equivalent in order to connect the mic on the adapter and the adapter with a
USB cable at your computer. It's a better but more expensive solution.
In case of a problem or clarification, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.Thanks and regards
Please kindly rate this solution
Stelios
direct
fixya link: http://www.fixya.com/users/technical114
