SOURCE: 1- Panasonic 7'' monitor model # CQ-VA707WEUC
Sounds like an inverter problem. If the power supply is internal replace the capacitors coming out of the voltage regulators. These are usually 1000mf and/or 470mf. If that doesn't do the trick look up the numbers on the 8-pin chips that drive the secondary transformers on the inverter to see if they are getting the right voltages.
Good Luck!
SOURCE: - Panasonic 7'' monitor model # CQ-VA707WEUC 2- Panasonic brain model #YEPOFX3799
you hold the next track button 15sec at the code screen
