I found the manual at ManualsLib here: https://www.manualslib.com/manual/487406/Craftsman-351-22632.html .
I hope this helps.
Need manual for 351.22638 not 22632
I'm sorry about the error. I can only find this parts diagram for the 351.22638,https://www.searspartsdirect.com/model-n... .
SOURCE: Need owners manual
Go to Searspartsdirect.com and type in your model number it will take you to another page where you can look at a breakdown or get a manual ( on the right hand side) you will need to sign up for a free access account to get this manual. I checked and they do have it about 32 pages long
SOURCE: need a manual for a Craftsman belt & circular sander
I found a PDF file on Sears.com website for the original manual for my belt / circular sander.
SOURCE: Finding parts for Craftsman 4x24 sander model
craftsman belt sander just stopped - does craftsman still have life time warrenty?
SOURCE: I need manual for Craftsman 315.11720 belt sander
On my model 315.11720 3"x21" Craftsman belt sander to change out sanding belts you push the front roller in until it clicks to lock in its retracted position (a pry bar may help here), switch out sanding belts then unscrew the tracking tensioner a bit on the opposite side with a allen wrench until the roller snaps back in place. I never remember anything about using a screw driver to force it back forward position again. Then readjust the tracking if necessary with a few short sanding load tests and you're good to go. Oil is dropped in the front roller center by removing the flat head screw - it should say "Oil Here" around the screw.
