SOURCE: lA PAVONI PISA
Ah ha! I just fixed the problem.
The black steam knob is bonded to the shaft. The shaft/knob assembly is removed by rotating the spring keeper on the brass housing the shaft fits into by 90 degrees to allow the shaft to be pulled out once the knob is rotated enough to disengage its thread from the brass housing.
Once the cover over the boiler is removed you will see three thermostats mounted on top of the boiler.
The middle one has the reset button located between the two power connectors. Push it down and you will hear a metallic snap as it resets.
I now have a working La Pavoni Pisa Espresso Machine again and it was free to fix it!
Wooo Hooo!!!
SOURCE: la pavoni pisa
I used this site to reset the La Pavoni Cellini machine. The first time it happened I didn't know what it was and sent it back. What a waste of money. All you have to do is unscrew the top with with an small allen wrench, there are three little things plugged in all in a row right on top. Push the second one in. Easy. Thanks to Ckimbo. You saved me a lot of $.
