SOURCE: Rockford Fosgate Problem in Nissan Titan
some decks save different settings on different sources. Make sure that the bass settings are not up higher on the radio sources and lower on the CD sources.
SOURCE: 1000 crossfire bmf and a rockford fosgate that need to be fixed
send the rockford to landis technical-they bought up all the parts to rockfords amps and will get them back to factory specs and recertify it for ya along with a new power certificate-look on rockfords website and snoop around and it will break it on down for ya and give you the address n stuff. i had to send my 1501bd mono amp in to get an overhaul and it came back throwin 1810watts rms so that was better than when i started -good luck.
SOURCE: 401s Rockford Fosgate Amp. Not powering on,just protect lite is on.
the problem is mostly with your audio side of the amp. i have a 800 Rockford punch series amp hooked in series running at about 15 vdc at 2 ohms stable for now. but the amps left front power side transistors overloaded and smoked out, i will be replaceing my mosfets soon. Now on that side your issues apear to be related to the signal side of the amp. when you hooked the amp up tell me breifly did you hook the rca inputs to the back of the sterio and did you select the proper rca inputs for the amp? also note that amps have a potentiomater that can be tuned up or down to allow the volume or wattage to go up or down threw the system. if it's turned all the way down you'll here nothing. but often you'll get a pop sound or quickly see the speaker move a bit. this indicated the signal side of the amp has signal comming in but no output, just look for a turnable small screw inside the amp top or side. and turn up acordingly. note: to much output will damadge your system. not just the amp. ;)
SOURCE: I'm looking for a wiring manual for a punch 150 amp
Follow this link to the downloads page for Rockford Fosgate, you can choose the correct manual there.
LINK
SOURCE: Error code E 03 on a Rockford Fosgate 6 disk CD player
I am having the same problems. Did you ever figure out what was wrong?
