Hello Pam,
We are sorry for the frustrations you are experiencing. We recommend turning the circuit breaker off for at least a minute to reset the Oven. If that does not work please email us at [email protected] with your name, phone number, street address, zip code, model & serial number, date of purchase on the appliance and a brief description of the problem you are experiencing. Thank you.
Best Regards,
Whirlpool Social Care Team
SOURCE: B3101 AEG oven cuts out after approx. 15 minutes - why?
this is probably the thermal cut-out causing the problem. not sure where it is located but possibly on the roof of the oven or in the rear casing near the fan. however, the cause may be lack of ventilation to the unit as a whole
SOURCE: Whirlpool Oven AKZ101/1X serial 858510115001 140349004758
Ensure the oven knob is set to 0 (zero) and press the reset button in the middle
SOURCE: Whirlpool Double oven - control panel stopped working
Atlanta...sounds like you may have a power supply problem or the panel is bad. Cut the power, open the unit up and see if there is a fuse in there or a reset. No good? Then replace the circuit board. They just, well, die sometime. Happened to my microwave. Some units may be available remanufactured. Look around on the web.
SOURCE: tricity bendix double oven
My oven's fan is working but no heat what so ever what shall i do
