First, I'm not an ELEMENT TV tech. But I do have a background in electronics.
* I checked youtube for "ELDFT406 tv" and there seems to be a lot of problems with this set. Looks like your LED back lite is not working. This can be repaired but as it come outside the USA and may not have a repair center in your area. I suggest returning it for refund or replacement. Though I would prefer a cash out and get another brand.
Aloha, ukeboy57
SOURCE: half screen showing
ok
keep tv off.
it will only get wors
if sumon dosent work on it soon
the problem you are having in the vertical section of the tv
hav a repairman resolider all conection on the vertical IC and check the serounding componets for falts.
regards daniel.
PS the repair takes me about 15 min.
SOURCE: Screen is half dark and whistles when battery is unplugged
You could have a defective screen, either a faulty inverteror a CCFL lamp - follow this to determine the fault.
Defective CCFL backlight, it may have the following symptom:
All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp
Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight.
Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out www.lcdparts.net for parts, repair service and DIY info.
SOURCE: Element 26 model ELCHS 261. The tv powers up ok but
has problem on the board.the solder is loose or loose solder
SOURCE: I have a InFocus 4805. Half the picture is darker
Your light tunnel may have collapsed. This is made up of 4 tiny rectangular mirrors glued together to make a tunnel.
SOURCE: Screen Half darker
Try also resetting the your monitor back to factory settings from the forteManager software that comes with it. It's under Options, Restore. I had a similar problem and this fixed it for mine.
