Http://www.google.com gives several manuals.
The following manual is free online:
http://phone.manualsonline.com/manuals/mfg/panasonic/kxdt333_1.html
SOURCE: KX-DT333 - Flexible Button (programmed
It probably means the phone is in Do Not Disturb. There's a programming option to make it not do that. Check out the installation manual for your phone system.
Carl
SOURCE: Hi I would like to
To what? There's a complete table in the Operations Manual (OM) or can you remember 0, 1 and 2? 0 assigns single lines....don't touch them. 1 plus ext assigns intercom numbers, and 2+access code and number is used to set personal speed dials (you also have 30 under the touch pad). Other commands set up Transfer to VM, VM record, CID display, Headset mode, etc. etc.
If you don't have a copy of the OM, here's one. Please rate this solution because as soon as you do, or after a short time, this manual will be gone. http://public.carl.airpost.net/misc/200_TDA_OM_10-11.pdf
Carl
SOURCE: I have the red light
Press MESSAGES and look at the display. It will tell you where the message came from and the 3rd softkey will let you erase the message.
l
Car
