Kitchen Appliances - Others Logo
J
Jimmie Dean Posted on May 07, 2018
Can you cook a small frozen pizza in a deni sandwich maker 1400 watt?
5 Related Answers
Anonymous
  • 1734 Answers
  • Posted on Sep 02, 2009
SOURCE: download owners manual for rival sandwich maker
If you can´t get it with google, ask manualfox.com
This is commercial, but they will get it for you for sure.
Anonymous
  • Posted on Jan 16, 2010
SOURCE: sandwich maker recipes
Found this on another website... not sure where... just had it copied to my word document... but here it is.
Warm up sandwich maker first…. Then spray with cooking spray.
Fruit pies
Two pieces of bread and apple pie filling (2 Tbsp)… cook 2-4 min Sprinkle with cinnamon and sugar when done.
Hot pocket
Ham and cheese
Breakfast
Egg Sandwiches
Egg Bacon and Cheese sandwiches
French toast… batter and cook, sprinkle with cinnamon and sugar? Cover in syrup
Pizza pockets
Cheese sauce and pepperoni
Mexican Fare
Using Tortillas add meat, cheese, or peppers
You can use…
Pancake mix
Muffin mix
Cornbread mix
Stir and pour into the sandwich maker Cook until done a few minutes.
Anonymous
  • 1970 Answers
  • Posted on Jun 22, 2010
SOURCE: emmerson microwave oven and grill
mcdevito75 here, Follow the directions on the frozen pizza package, Or simply microwave at 2 minute intervals till the pizza is done or fully heated up.
drifterK
Catalin Turcu
  • 4924 Answers
  • Posted on Jul 24, 2011
SOURCE: I purchased a Breville Electric
Try to soak it first with some solution used for cleaning the gas range ...and let it stay with the detergent on for a while (about an hour ) and after that try to clean it and see what is going on ...repeat the procedure if needed..and also rinse it well cause it will be in contact direct with the food..
Ian Center
  • 258 Answers
  • Posted on Jan 01, 2015
SOURCE: instruction manual gordon ramsey cuban sandwich maker
our best bet is to go to YouTube and type the question there and you will more better get the answer you need for a more hands on..
Panasonic microwave
I would check the cooking instructions on the side of the pizzas packaging. If microwave cooking is not listed I would not recommend cooking it in a microwave as this could make the food unsafe to eat.
But if you're short of an oven I have found a guide on barbecuing a pizza:
How to Cook Pizza on Barbecue
1helpful
Bake pizza
I would check the cooking instructions on the outside of the pizza packaging. If microwave cooking is not a suggest method I would not try to cook it in a microwave.
Food in microwave is burning on edge and cold in the center
you may find the old unit was lower watts so took longer & cooked/heated better all the way through. a way to fix this is lower temp settings or pause and stir the food to help heat it up more even.
The lower element has gone out and the top broiler element is all I have. The using will be four years old in January 2014. I need a replacement element to take to my small appliance repairman.
1)you must test the lower elements with multimeter, using the resistance, and test it,2) see if there are some wires frozen and repair or replace,3) clean and readjust the solenoid for dirty, or oxide,
God bless you
I am looking to buy a sandwich maker like the 17936 and set it on timer for the morning so they are ready for when I wake up and go to work - does this russell hobbs model heat up and then stop heating...
Here are a few links to some information about the Russell Hobbs Model 17936 Sandwich Maker:
http://www.amazon.co.uk/Russell-Hobbs-17936-Sandwich-Maker/dp/B002MRS1NM
http://www.reevoo.com/p/russell-hobbs-2-sandwich-maker
http://www.sonicdirect.co.uk/catalogue--iID--5785--russell-hobbs-17936-2-slice-sandwich-toaster-in-brushed-stainless-steel.php
I don't think you will find a small sandwich maker with the type of automatic timer you are describing. Most full size digital ovens have that function, but very few smaller units like the 17936.
Also, would it not be a bit impractical to leave a sandwich with perishable toppings in the machine overnight in order for it to begin cooking in the morning? Any kind of meat product left out overnight unrefrigerated may become dangerously contaminated and spoil.
For all the time these machines take to heat up, you might as well just get up 5 minutes earlier in the morning and prepare your sandwich then.
Good luck though either way.
1helpful
2answers
Why does food get hard after cooking or reheating in a microwave
It's basically a loss of moisture during the cooking process, to avoid this in a standard oven cook on a lower temp for longer and cover with foil....in the microwave, drop the power setting and always reheat or cook with the food cover with a microwave safe cling wrap or microwave specific cookware with lids.
Hope this helps.
3helpful
Emmerson microwave oven and grill
How do you convert cooking times on packaging to match the wattage of the microwave?
The cooking time for a 700, 1000 or 1100 watt is broadly defined.
Typically, it depends on what you are cooking. What is the wattage, and I will convert it for you. Melba
Cooks essenial small pressure cooker
Keystone is the manufacture for the Cooks essentials K5963 pressure cooker. Keystone authorized Deni to sell the same product as the Deni model 9700 Pressure cooker. I found the manual on the deni site in PDF formate. This is the exact same pressure cooker with a different name on it.
http://www.deni.com/index.cfm?fuseaction=page.product&category_id=27&product_id=21
3helpful
Sandwich maker recipes
Fruit pies
Hot pocket
Ham and cheese
Breakfast
Egg Sandwiches
Pizza pockets
Mexican Fare
You can use…
Pancake mix
Muffin mix
Cornbread mix
Top Deni Kitchen Appliances - Others Experts
ADMIN Andrew
ADMIN Andrew
Steve Pack
Steve Pack
Tanishq Anand jagga
Tanishq Anand jagga
Are you a Deni Kitchen Appliances - Other Expert? Answer questions, earn points and help others
