SOURCE: msi u100 bios password
Turn the laptop upside down and remove the plates one by one. Wherever you see a button cell, remove it for a minute or so and then reinsert it and put back all the covers. Power on and boot up the laptop. And remember not to use the password again. And if you have to then use such that you can not forget ever.
SOURCE: i have a msi u100 series netbook.my problem am hav...
This information is intended for experienced users. It is not intended for basic users, hackers, or computer thieves. Please do not try any of following procedures if you are not familiar with computer hardware. I'll not be responsible for the use or misuse of this information, including personal injury, loss of data or hardware damage. So use it at your own risk.
A. By Using the Motherboard Jumper:
In most motherboards CMOS battery is soldered, which makes it difficult to remove the battery. In this case we use another method.
Almost all motherboards contain a jumper that can clear all CMOS settings along with the BIOS password. The location of this jumper varies depending upon the motherboard brand. You should read your motherboard manual to check its location. If you don't have the manual then look for the jumpers near the CMOS battery. Most of the manufacturer label the jumper as CLR, CLEAR, CLEAR CMOS, etc.
When you find the jumper, look carefully. There will be 3 pins and the jumper will be joining the center pin to either left or right pin. What you need to do, is remove the jumper and join the center pin to the opposite pin. e.g. if the jumper joins center pin to left pin, then remove it and join center pin to right pin. Now wait for a few seconds and then again remove the jumper and join the center pin to left pin.
Make sure to turn the PC off before opening the cabinet and resetting the jumper.
B. By Using Software:
I have found that BIOS/CMOS Password Recovery Tool is the most effective.:
BIOS/CMOS Password Recovery Tool is a program that works instantly to remove any lost or forgotten BIOS/CMOS password. Simply boot your PC to DOS and execute the program, and get access to forgotten BIOS/CMOS passwords in just seconds
BIOS/CMOS Password Recovery Tool Service: http://www.biospasswordrecovery.com/
SOURCE: cannot remove msi u100 bios
To reset the BIOS read the information from this link.
In case of your laptop the easiest method would be using software from Hiren's Boot CD as it's pretty hard to open it up and reach for the CMOS battery or the jumper.
SOURCE: My niece has somehow set a password on her msi u10...
Hope this post can help you:
http://www.windowspasswordsrecovery.com/crack-dell-laptop-password.htm
Scott, I am befuddled. I have an MSI U100 and do not know the bios setting. The Internet is full, and I really mean full, of people asking how to resent the bios, then people imediatelly reply with the incorrect answer about removing the battery, then people reply saying that does not work, and the thread ends there. Why would you suggest such a solution without googleing it first?
