Alison Francis Posted on Apr 27, 2018
My archos 50b won't turn on - Archos Audio Players & Recorders
tip
Alternator warning light stays on after the start.
Swap the wiring of the ignition switch for terminal 50 and 50b around. Now terminal 50b is switched on first to activate the alternator and the alternator warning lamp goes off during the start.
on May 19, 2008 • 2005 Audi A8
Why won`t my USB recognise android MID tablet
Is it going through a hub/switch. If so, try direct connect.
1helpful
My archos WON'T TURN ON.
check the power supply connection i.e., battery connection and AC connection
Archos 2 OC won't charge and is not recognised by laptop
Sometimes with mp3 players the cable is the one that is mostly damaged. Try replacing this cable and try again. It actually has happened to me on two different mp3 players. Cables are always faulty.
Archos 70 won't turn on
I have the 8gig Archos 70, the whole thing froze as described in other posts. The solution is not for the feint of heart though. Mine would do absolutely nothing. So what the heck, I opened it up (nothing to lose at this point). Messed about a bit. Read that when it "Bricks" like this there is nothing that can be done. If it is Bricked, something locks it in the memory and function. As long as the battery is connected, it will remain that way no matter what.
Solution. Cut the black power wire from the battery (there are three long wires red white and black), leave for 20 minute, and solder the wire back together and heat shrink the joint. Reassemble, plug in power cord and it should reboot...
My archos is about 3-4 years old, and is mounted to the wall in my kitchen for use as an internet radio
6helpful
3answers
Brand new archos arnova 10 tablet. It is stuck on the charging screen. Won't turn on or off. Have hit the reset button. Didn't help, continues the same problem?
To hard reset a tablet, hold the power button down until it shuts off then press it to turn back on. Should take about 5 - 10 seconds for the device to power off.
How I can to restore my Archos 70b eRider after attemption to install the the new version of firmware (1.0.4). After loading the new update.img from www.archos.com it is stopped on the first screen and...
U HAVE TO TAKE IT TO UR SERVICE CENTRE BECAUSE IT PROBABLY LOOKS U HAVE INSTALLED WRONG FIRMWARE AND U MAY HAVE TO REPLACE THE PHONE .BUT FIRST DO TRY AT UR SERVICE CENTRE,THEY MAY FIX IT.DO VOTE FOR ME IF PROBLEM FIXED.
1helpful
6answers
MY ARCHOS PLAYER WONT WORK
Just watching a movie and my archos just froze in mid play , did a switch off to rest it and guess what it wont restart , ses ARCHOS in green at the start but wont reeboot have tried the reset button inside but no joy what so ever , any tips or advice 'or shall i just ship it back to Archos ....
Top Archos Audio Players & Recorders Experts
 Grubhead
Grubhead
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you an Archos Audio Player and Recorder Expert? Answer questions, earn points and help others
