20 Most Recent
mid Archos M729B Android Tablet Questions & Answers
It says unfortanitly android 4.0 has stopped
Most Android issues are easily fixed by just restarting your tablet/phone/etc.If you get an error message, if it becomes too laggy or anything unusual, restart your device.If you still have the issue, then it may be something more serious!
I cant remember my draw pattern to unlock
just make a factory data reset.
To reset you tablet manually. you have to
1)switch of your tablet
2)hold volume down button and power button at the same time.
3)wait for 10 sec and you will enter into boot menu.
4)there in the boot menu you will find option named Reset factory default settings/reset user data. select that option
5) wait for resetting......
6)cheers your done.
Need the stock rom for a mid 729b?
Can you tell me where you got the upgraded rom from, and have you tried downloading the firmware from the manufacturer's website? http://www.archos.com/us/support/support_tech/updates_fwm.html
How to reset the a teblet
Look on the bottom where the other ports are. The reset button is the tiny hole between the HDMI and headphones jacks. Use a paper clip ti reset. Make sure you feel the click as the button is really small. Cheers Keith
Forgot pattern to get in it
You will need to perform a factory reset. - Turn off the device and wait 10 seconds. - Press and hold the volume + button while powering on the device. - Keep the volume + pressed until the Recovery mode starts (white screen). - To move from one option to another, use the volume buttons. To select an option, press the ON/OFF button.There should be an option to factory reset or erase your tablet.
How can unloxk ipad foegot password
You have to plug the iPad into the computer that you originally connected it with. Then you have to "restore iPad to factory settings". This will of course erase all your data but at least you will have your iPad back.
Mid m729b will not shut down
A bit late but FWIW, I had this problem. I eventually just moved any data I needed to a safe place & fully reset it. To reset, hold the power button & volume up button simultaneously. It should boot to a screen that tells you what to do next. I think they ask you to keep holding the power button for a reset. Do that & you'll see a big old 3D Android figure & a blue progress bar. Give it a minute & it should eventually load. After that I got a screen that said it was "updating" & gave me a percentage countdown. It finally booted like normal to factory settings. All of my data was gone but it now turns on/off like it should.
