Computers & Internet Logo
b
boopathi Posted on Mar 18, 2018
Nokia 6070 keys 2, 5 and upper arrow key not working.
I have cleaned keyboard and keyboard connecting jumper with thinner, but problem not solved.
5 Related Answers
Anonymous
  • 239 Answers
  • Posted on Jan 15, 2008
SOURCE: Keys dont work.alternative way to change brightness?
Yes you can go into your display properties and look in the settings tab and look for advanced click that and open color tab or the overlay tab, color tab should get your brightness turned up, And if you can't see you can go into your bios and adjust your brightness from there and get it back to where you can see it if you can't write me back here so we can try another method. Ok I hope that helps you out somewhat, Oh yeah you can also hook up an external key board into your usb connections and you should be able to work everything from that too.
Anonymous
  • 46 Answers
  • Posted on Mar 07, 2008
SOURCE: types in upper case only (without caps lock/shift key locked)
in most cases yes, BUT since the light for caps lock is not comming on you might have a bad P.O.T. on the keyboard layer.. Since im assuming we are talking about a laptop..
A
Anonymous
  • Posted on Oct 31, 2008
SOURCE: 2 keys(reeds) are not working ,my keyboard is yamaha DGX200,how to open it
عزف
Anonymous
  • 121 Answers
  • Posted on Jul 06, 2009
SOURCE: Ok, my laptops keyboard is going weird
The keyboard is retiring. The keyboards are not terribly expensive. You can obtain one from your local agent and replace it or have it replaced by them
Anonymous
  • Posted on Aug 03, 2009
SOURCE: Nokia 6070 keypad not working
change keypad ic
What is the problem why the arrow keys functioning differently.
Disconnect and reconnect your computer keyboard, then restart your computer.
Sometimes a poor connection can result in keys not working on your keyboard
Update the device driver for your keyboard by going to the manufacturer's website of your keyboard, and then download and install the latest driver matching the brand and model number of your keyboard.
Disconnect your keyboard from your computer and inspect the pins in the keyboard connector if you have a PS/2 connector.
The PS/2 connector for your keyboard has six pins, which connect into a PS/2 port of your personal computer, to allow for communication to and from your keyboard.
Straighten any bent pins you may find, by gently using a ballpoint pen.
You must replace your keyboard if you see broken pins.
Try testing your keys using a different application, such as another word processing program. Keys like the function keys on your keyboard labeled F1 through F12 may not work in one application but will work fine in another.
Clean Under Desktop Keys
Disconnect your standard desktop keyboard, then press down on a key not working.
Slip a car key or a flathead screwdriver underneath the key.
Twist the screwdriver or car key until the keyboard key pops off.
Use a damp cloth, moist cotton swabs or compressed air to remove dust, hair, and food crumbs under the key.
Use only water or rubbing alcohol to moisten the cloth and cotton swabs---other cleaners can damage the plastic of your computer.
Position and press down on the key to snap it into place.
Repeat this for all of the keys to clean underneath them, if necessary.
hope this helps
Problem in my keypad in nokia 6070
My Dear your phone keypad ic default so please change keypad ic
and keypad problem will solved
My phone 6070 has problems on key pad.sometime 1 is not working and some times 2..how can i solve this problems.
open your set, take out keyboard, check all pin of keyboard connector, also behind the keyboard, clean if necessary.
3helpful
Nokia 6070 key pad 3, 6, 9, # key not working i
Sorry to say this please replace keypad crstal IC,and jumper it will work 100% ....reheat the upper components and the the whole pcb,with care,the keypad ic is same as 6600, 6630, n70, 6680, 6280 LCD IC.
Please do rate the solution if the issue is resolved or post a comment for further assistance.
thank you for using fixya have a nice day:-)
17helpful
3answers
Reset my nokia 6070
Press "green key" + "*" + "3" + "power up" old all keys untill you see formating screen
Menu & key pad (no-)2 not working
remove its keypad, wash it's contact surface(which is made up of rubber) with soap and water gently then dry it thoruoghly , refix it n u r problem is gone :)
please do care to rate my solution . thx
2helpful
Insert sim
just clean the connectors, thats it
31helpful
2answers
Power switch connection
sir' my nokia 6070 on/off switch is destroyed.could you plz show me how make a jumper to restore the track.
2answers
Toshiba A105 keyboard
Your keyboard or motherboard could be failing. Would suggest calling manufacturer for support to get it repaired.
Top Nokia Computers & Internet Experts
k24674
ADMIN Andrew
ADMIN Andrew
 Mikey
Mikey
Are you a Nokia Computer and Internet Expert? Answer questions, earn points and help others
