Marcus Wootton wants more answers to this question \
PC is 5 years old max today. 2014 made.
they answered this , here 10,000 times
you have 2 choices, (no jumpers here those ended long ago.)
1: dell.com ask for free help
2:http://biosremoval.com/
Call Dell support toll free number 1-844-395-2200 USA AND FIND instant support for your dell heating problem by expert technicians.
SOURCE: lost system password
Only way to remove a BIOS password on any computer is to remove all power sources from the motherboard so its memory can be cleared.
First, remove the main battery from the laptop. Then you must locate and find the little coin cell battery (It looks like a watch battery) on the laptop and remove it for about a minute or so. Then you can replace them in the opposite order.
Your coin cell battery is in a bay on the bottom of your computer. Enjoy!
1.
Before removing the coin battery:
2.
Locate the memory module cover on the bottom of the system.
3.
Use a Phillips screwdriver to remove the two screws securing the cover.
4.
Lift and remove the cover from the system.
5.
Locate the coin battery.
6.
Use a fingernail (or small flathead screwdriver, if necessary) to release the battery ZIF connector.
7.
Remove the battery from the chassis.
8.
Reverse the previous steps to replace the coin battery.
SOURCE: NEED ADMINISTRATOR PASSWORD FOR DELL LATITUDE C600/C500
If this password is for Windows, then you will need to contact who set the password originally. Optionally you may use tools online to reset the password. This would require purchasing a utility like SpotMau.
If this password is for the computer it self, before booting to the OS, you have to remove the BIOS battery to clear the BIOS password.
Removing the screws on the bottom of the laptop, the bezel at the top and the keyboard, check the bottom and top of the system board, you should see a flat-cell battery or a plastic coated series of batteries with a cable going to the system board.
Good luck
SOURCE: Dell Inspiron 6400, asking for HDD password
Insert OS cd in drive and start reinstalling by selecting repair mode
now once all files are loaded system will reboot when you see the Installing Devices progress bar, press SHIFT + F10
this will give you access to your account also you can reset all passwords
Now restart lappy and let the system boot normally without OS cd in drive
now
you will come to old screen and previously configured desktop with all
intact aplication and icons on desktop and it will no more ask you for
password till you set a new one
Thanks and regards
Kindly rate this solution
