SOURCE: my motorola v8 wont connect to the internet or my pc
I have the same problem when trying to get my PC to recognise my V8. I went to the Motorola website for updates and the V8 is not even one of the options!!!! This is a classic example of BAD RUBBISH support for users. Motorola MUST be aware of this problem and do they supply any help? Of course not. So I say to all people reading this: Don't tolerate poor customer service and contact MOTORALA and DEMAND better support.
SOURCE: jum error 102 on blackberry bold
https://www.blackberry.com/Downloads/contactFormPreload.do?code=1141938BA2C2B13F5505D7C424EBAE5F&dl=20E9452CEC42D5E5133B1895B4AE7906
Requires you to fill out registration fields, but it's free and it should help you resolve your issue.
SOURCE: How to setup internet between 2 EnGenius EOC-2610 devices?
Thanks for a very thorough problem report. It's a little ambiguous near the end, though, so I will have to restate what I think I understand you are saying.
You are saying that you have your internet connection and AP in one building, and two devices or PCs in that building can access the internet and share files (though you don't specify if they are using the EOC-2610 access point or are just accessing the router in some other fashion). But you have a remote building where there is one PC and one EOC-2610 in Client Bridge mode, and although both EOC-2610 units seem to be communicating with each other, the PC will not communicate with anything. (I presume you have inspected the access point's configuration screens and verified that it does have the other EOC-2610 listed as a connected client.)
First, the PC in the remote building has to be connected to the Client Bridge EOC-2610 by its ethernet cable in order to access the network. Second, the PC in the remote building has to have a valid IP address in the range 192.168.0.0/24, or it won't communicate with anything. If you are relying on your router's DHCP to assign your PC an IP address, verify that this has happened by examining your PC network properties. If you are assigning all IP addresses manually, make sure you have assigned the PC an address, and one that doesn't duplicate some other device.
Sometimes failure to specify DNS servers appears to be a lack of communication with the network. Open a browser and type 66.70.119.204 in the URL bar. If you get to fixya.com, you have a good network connection. If you type fixya.com in the URL bar and can't get the same result, you need to define DNS servers on the PC (or inside your router).
