SOURCE: Pioneer Elite Pro-99 Power Problem
If you're NOT still under warranty you should at least open the TV and look for a blown fuse near where the power cable enters the set. A lot of times you can buy replacement fuses at a local electronic or hardware store and they're easy to replace. Check the fuse. If it is blown, it will be obvious and make sure that the set is unplugged before replacing it. If it blows again, or if it is not blown, your problem is probably in the 'X' volt regulator and you will need professional help with the repairs. You can also check the board where the components are mounted and resoled any that look bad. Brief power outages may cause the TV to turn off on its own. If you are using a surge protector, try connecting the set directly to the wall outlet. In your case it could caused by a blown fuse, a leaky diodes or a bad solder joint at the horizontal drive transformer. All can be replaced at a local electronic or hardware store and they're easy to replace If this does not correct the problem, you may need to have your TV serviced. good luck!
SOURCE: TV repair man said that the regulator BSC 62A is
TV repair man said that the regulator BSC 62A is damage. When apply power to TV on the power light on the front of the TV comes on but nothing shows on screen. Whats wrong?
SOURCE: Power button flashes red. TV comes on momentarily
this is a inverter board defective. please change-it
SOURCE: I just bought my treadmill today from Sears as a
I have a Sear Nordic track exp 1000 x for 5yrs now...for the past 1 1/2 yrs the treadmill has been giving me problems, when I'm walking for 20min sometimes less the treadmill turns off & it doesn't want to go run. I noticed that it smells a little like if it was burning. What can I do to fix it or what can it be? Please help!!!
SOURCE: NordicTrack T5.3 belt stopped working. It's only 1
HI, its seems like the belt on the motor has either slipped off, or you just need to tighten it. best way to find out is to take off the front pannel showing the motor. then stand on the treadmill. start it and you will see the problem.
