The fan no longer works and the heater clicks twice when it is turned and nothing happens.
SOURCE: I have a 2005 chevy
Treed55508,
Try this solution. I have had the same issue three times. A Chevy tech told me that if it keeps doing it, to replace the blower motor, as it seems to be a chronic problem with the blower having to much resistance and thus burning out the resistors. I suspect that you probably had lost one speed first and then more. It has happened both ways with me, once the entire thing went out at once and then the other times it goes one speed at a time.
http://sparkysanswers.blogspot.com/2008/07/2005-chevrolet-silverado-blower-inop.html
SOURCE: heater fan has stopped working in honda accord 92
The blower motor has died, you will need to replace it and last time I did one they were quite expensive (300 bucks), but the prices may have come down
SOURCE: Noritz tankless water heater not producing hot water
I called Noritz error code 16 is a overheat problem. Noritz say's to flush your coil with vinegar or CLR.
Use a small pump to recirculate the CLR or vinegar through the system for 45 minutes and flush with fresh water. This worked for me.
SOURCE: Noritz tankless water heater/dishwasher not hot enough to clean
You are doing everything you can. Your dishwasher probably isn't drawing enough hot water to activate the unit so opening the faucet and flowing more water will activate the unit. Just try to adjust the flow from the faucet to a point it, plus the draw from the dishwasher, will activate the unit. This will come with trial and error as I am sure you have already experienced. Also, open the dishwasher when it does get filled and check the water temperature. You might have the unit set at a low discharge temperature. Do you have a touchpad to control the water temperature adjustment?
SOURCE: Paloma PTG 74PV N1 Tankless Water Heater - stops heating
Most likely problem is the remote control not the main board. A safe temporary fix is to unplug the heater from the 110 volt outlet, remove the two low voltage wires from the remote control and use a small wire nut to connect the two conductors together. Plug the heater back into the 110 outlet and the heater should work just fine. The default water temperature is about 118 degrees at the heater. Replace the remote control ASAP.
