SOURCE: timex T618
You can download the manual from the link below: http://www.timexaudio.com/pdf/T618_IB59176_84.pdf Please update the question & let us know if the information given was useful to you - Good Luck!
Hello
The backlight LED of your Timex clock has got weak. It should be replaced. But it is really a skilled work as, you have to disassemble the display unit. If you are aware in electronics and have skill to do this work, you can do it by yourself. Otherwise, it will be best to get it replaced by any experienced service technician. OK.
This alarm clock radio features an adjustable display backlight, with dim, medium, and bright settings. To
select a backlight setting, press the 3 Snooze/Dimmer Bar until the desired brightness is reached.
Please note that the backlight will not work while the clock is operating on battery power.
OK
