20 Most Recent Timex T158W Clock Radio Questions & Answers
manual
manual
How do I set the
CLICK HERE for your user manual.
You can save or print it for further reference.
Setting the clock is inside. (page 6) as follows...
Setting Clock Time and Calendar
Important - While setting the time or calendar, if you do not press the appropriate buttons
(as explained below) within approximately 8 seconds, the display will stop flashing. If this
happens you must follow the instructions again from step 1.
Setting the Clock Time
1. Press and hold the Time Set Button until the display begins flashing.
2. Press the FWD/Month or REV/Date Button to select correct time. Remember to
set the correct AM or PM. The PM Indicator is located on the upper left side of the time
digits (there is no AM indicator).
3. Press the Time Set Button again to return the display to normal mode. You can also
allow the display to flash for approximately 8 seconds to return to normal mode.
Note: While setting the time, if you press and hold the FWD/Month or REV/Date
Button the minutes will begin counting at a moderate pace, then get faster. This will
assist you in easily setting the time quickly and accurately.
Thanks!!
11/12/2010 2:58:39 PM • Timex T158W... • Answered on Nov 12, 2010
Forgot how to set time.
Thanks!!
11/12/2010 2:57:08 PM • Timex T158W... • Answered on Nov 12, 2010
How to stop the alarm on a Timex T309 clock radio?
Page 11 of the manual refers (complicated)https://www.manualslib.com/manual/379730/Timex-T309tt.html?page=11#manualAn easier way would be to pull mains plug and remove the batteries for 5 minutes, reinsert, plug in and set the time...
11/20/2021 7:20:28 PM • Timex Audio... • Answered on Nov 20, 2021
Please help me. I need to reset the time Timex Alarm Clock Radio T231Y INTERTEK4008151
First turn off the radio feature of the clock by pressing and holding the Mode/Alarm Reset button. That is the right-most button on the top of the clock as you look down on it from the front. You may need to do this step twice to see Off in the display. Next press and hold the Preset/Clock button on the far left. Now use the Hour and Min buttons (the two buttons to the right of the Preset button) to set the current time. When the correct time is flashing, press the Preset/Clock button. The display should stop flashing and the clock will run. I hope this helps. The documentation for the Timex T231 is currently available here: https://cdn.ihomeaudio.com/media/product/files/T231_User_Manual.pdf . A quick start guide is also available here: https://cdn.ihomeaudio.com/media/product/files/T231_Quick_Start_Guide.pdf . Cindy Wells
11/1/2020 5:50:35 PM • Timex Audio... • Answered on Nov 01, 2020
Set time on Timex T1201 NATURE SOUNDS CLOCK RADIO
Step by step instructions according to the web site below: https://itstillworks.com/12239635/how-to-set-a-timex-auto-set-nature-sounds-alarm-clock
11/4/2019 10:58:41 AM • Timex Audio... • Answered on Nov 04, 2019
I need the instructions for setting the clock and alarm for a Timex T618T
Here is a link to download the manual. It has the instructions...
https://www.manualslib.com/download/588746/Timex-T618.html
9/30/2019 1:59:53 PM • Timex Audio... • Answered on Sep 30, 2019
I have a timex mini alarm clock i was wondering does it need a battery and what size is itwould like to get it working
look on back and or remove battery cover for info
8/22/2019 1:32:32 AM • Timex Audio... • Answered on Aug 22, 2019
How to set radio station on timex radio clock model t311t
Hello Glenn, I sent you the link to download the user manual of your Timex and follow the steps to configure the radio stations Keep in mind that if the radio station is far away, you may have trouble tuning it I hope you can solve your concern Greetings Franco Dosil Hola Glenn, te envio el link para que descargues el manual de usuario de tu Timex y sigas los pasos para poder configurar las estaciones de radio Ten en cuenta que si la estacion de radio se encuentra lejos, podriastener dificultad para sintonizarla Espero puedas resolver tu inquietud Saludos Franco Dosil https://cdn.ihomeaudio.com/media/product/files/T311IB57574_35.pdf
7/5/2019 3:32:47 AM • Timex Audio... • Answered on Jul 05, 2019
Who do you set the alarm on a Timex clock radio T235Y.
Hello Carey, you can find the alarm configuration form, which appears in the Quick Guide of your Timex clock radio T235Y. I sent you the link, so you can download it I hope you manage to schedule your Timex Greetings Franco Dosil Hola Carey, puedes encontrar la forma de configuracion de alarma, que aparece en la Guia Rapida de tu Timex clock radio T235Y. Te envio el link, para que puedas descargarlo Espero logres programar tu Timex Saludos Franco Dosil https://data2.manualslib.com/pdf4/80/7988/798701-timex/t235.pdf?4a0b39d025e7d16ec28f8e4574be1d11&take=binary
5/6/2019 4:39:23 PM • Timex Audio... • Answered on May 06, 2019
Need a battery foir an old timex travel alarm clock. 1.5 Volt VX-1 on back of unit
Contact a local jeweler
3/27/2019 1:13:27 AM • Timex Audio... • Answered on Mar 27, 2019
Timex T158W Clock Radio Logo
5 questions posted
Top Timex Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
Are you a Timex Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Timex Audio Players & Recorders
Most Popular Question
need set clock lost
  • Audio Players & Recorders
