Posted on Jan 27, 2018
Timex redi set alarm clock not working. It is a discontinued model T 736. It has dual alarms, soothing sound choices, AM/FM radio and time projection which we love having.
1 Related Answer
Anonymous
  • 8197 Answers
  • Posted on Sep 25, 2010
SOURCE: TIMEX Dual Alarm AM/FM Calendar Clock Radio -
On the manual below on page 7 and 8 will tell you how to set the alarm.
http://www.manualsonline.com/mdownloads/64580048-2a62-445b-b8f9-911293790997.pdf
Good Luck and please rate 4 thumbs up for the free answer
Testimonial: "Thanks, that was perfect.. You guys are great.. Timex web site didn't even list it.. Wow. Thanks again... Mike..."
2answers
On TEAK Alarm clock radio USB charging I want to make it wake me up with radio music not buzzer. How do I fix that
Can you comment with the model number? It will be on the information sticker on the radio itself. It will possibly start with 'CRX-'.
Try this - Press and hold the alarm set button until the display flashes like your setting the alarm time. Click the same button again and it should swap between buzzer and radio each time you click it. It will probably show some sort of logo on the display telling you which it is set to.
HOW DO i SET MY CLOCK AND ALARM ON MODEL RP4801A
PDF]FM/AM Clock Radio - Sony
https://docs.sony.com/release/ICFC218_US.pdf Sony CorporationVarious types of alarms - radio and buzzer. Automatic time set - When you plug theclock in for the first time, the current time will be shown in the display.
[PDF]Jumbo Display AM/FM Clock Radio - TIMEX Audio
5helpful
TIMEX Dual Alarm AM/FM Calendar Clock Radio - T433B Can't figure out how to set alarm time...
13helpful
2answers
Timex Indiglo, model T560B natural sounds alarm clock radio
Press alarm set button, time display will blink. Then press off/reset button to toggle hourly beep on/off.
12helpful
Lost manual for a timex t307s
Setting the Alarm 1 for AM/FM Radio
1. Press and hold the 2 Radio Alarm 1 Button. The display will flash and the Radio Alarm Indicator will appear. If
you do not begin setting the time within ten seconds of pressing the button, the display will stop flashing and you will
need to press the 2 Radio Alarm 1 Button again.
2. While the display flashes, press the 1 Reverse and 6 Forward Buttons to set the wake time. Hold a button for a few
seconds to set the time rapidly. Be sure to set the correct AM/PM time, as shown by the PM Indicator.
3. After setting the radio alarm time, while the display is still flashing you will need to select the station. First, press the
L Mode/DST Button to select a radio frequency. Next, select a station using the M Memory Set 1-6 Buttons. For
more information on programming radio stations into memory, see the Programming Radio Station Settings section of
this manual. Rotate the O Volume Thumbwheel to set the wake sound volume.
4. After setting the radio alarm wake time and sound, you will need to select the 7-5-2 setting. The 7-5-2 setting lets you
set the alarm for a full week, weekdays only, or the weekend. Before setting the alarm, be sure that the correct date
is set, as shown in the “Auto-Set” and Manual Time and Date Settings section of the manual. While the display is still
flashing, press the 9 Date/7-5-2 Button until the desired setting is shown.
5. After you have set the radio alarm wake time, sound, and 7-5-2 setting, press the 4 Enter Button. The Radio Alarm
Indicator
will appear on the display, showing that the radio alarm has been set.
Setting Alarm 2 for Nature Sounds/Buzzer
1. Press and hold the 7 Nature Sounds/Buzzer Alarm 2 Button until the Alarm 2 settings and Sounds Alarm
Indicator appear on the display.
2. Press the 1 Reverse or 6 Forward Button to set the Alarm 2 time.
3. Use the L Mode/DST Button to select a nature sound or the buzzer to wake to. There is a choice of five sounds:
Sound #1: Ocean Surf
Sound #2: Birds
Sound #3: Brook
Sound #4: Wind Chimes
buz: Buzzer
4. See Note #4 in the Setting Alarm 1 section for instructions on setting the 7-5-2 alarm setting for Alarm 2.
5. After you have programmed the Alarm 2 settings, press the 4 Enter Button or wait ten seconds to return to the clock
display. The Sounds Alarm Indicator will appear on the display, showing that the alarm is set.
2helpful
2answers
"unset" the alarm on Timex T300T clock radio
When you set the alarm you pressed aburron that said 'radio' and/or 'buzzer' then programmed the time. Just press the buttons again and the alarm will no longer sound. Looking at the dial at the top of the lcd screen you will see the word buzzser or radfio if the alarm is enabled. Pressing buzzer or radio on the side will remove the word and no more alarm!!
Luck----
Setting the alarm alternatives
No solutions yet - just bought the last display model off the shelf at Target with no manual (Timex T617S). I'd like to find a hard copy or online manual, or just some help from a kind owner of this clock radio.
9helpful
Setting time and alarm clock for timex nature sounds clock
Hold the time set key in until the time flashes. Now let it go and use the tuning forward and back keys to set the time. I had the same problem because I continued to hold the timeSet button down while trying to adjust it. If you do, the forward/back keys have no effect.
Top Timex Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
Are you a Timex Audio Player and Recorder Expert? Answer questions, earn points and help others
