Normally you just program by PLU number. If you run out of numbers then you may have filled memory. I don't know this model since it is not common. There is a manual on the net which might help - https://the-checkout-tech.com/manuals/cashregisters/Olympia_CM-811_and_CM-812_instruction_manual.html
SOURCE: After programming my TE-2200 Casio,
Read the 104th page of this manual.. It contains all the error codes and their resolutions..
http://www.casio.co.uk/pdf/cashreg/TE2200_User_Manual.pdf
SOURCE: How to change the names
try this mate:
http://www.cashregistergroup.com/acatalog/Sharp_ER_A_series_cash_register_section.html
SOURCE: i have olympia cash register
Make sure paper is loaded in printer, press the clear button.
If still problem try reset.
Key to PGM mode, disconnect power, hold CLEAR & 7, connect power. Should be ok.
greathttp://dragoncityhack2018.pen.io/
https://errorcodesfixer.org
Download Kingoroot APK V5.0.1 latest version for Android to root without Windows PC, get kingo root app from official website.
