Computers & Internet Logo
Posted on Jul 30, 2009
I have a new rane ttm 57sl mixer. Im getting audio output from both turntables to my headphones, but only one side's output can be heard through the speakers?Not sure if Ive hit something to shut down the one side's output.
Anonymous
Level 1:
New Friend:
  • Contributor 60 Answers
  • Posted on Mar 14, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
60
Questions
0
Helped
19689
Points
98
Is it on mono? or stereo?
Rane ttm 57
Check your pan control settings and the wireing to be sure it is not crossed.
2answers
Why won't both my turntables play out of my mixer?
I am guessing but it sounds like a gorse impedance mismatch. You should never connect two outputs together unless they are specifically designed for that. Since you are listing to mono why not send each output to the Base Amp the other to the cabinet. That should resolve the problem.
Plugged in power ac for my rane ttm 56 mixer during a storm....on a cheap power strip and my mixer wont come on....can my 120 power supply have blown or is it sumn wrg with my new mixer? it wont work on a...
Hallo! First you should check with a tester if there is present the voltage at the exit of your power supply, on the cord that goes to the mixer. If there IS voltage (usually 9...15V) then I'm sorry, your mixer is dead. But, for me, most of times is burning the alimentation. Cheers!
Hello, I am trying to plug my Mixer into my amp but only one speaker has sound..I am using a Rane ttm57sl mixer with technics turntables & cambridge audio azur 640a amp...I've gone from the Aux out on...
Why don't you try using the main outputs (the 2 XLR connectors). With 2 cables connect these two (left - right) outputs at your amplifier's aux in. In that case take care that the "output level" of the mixer works like master volume controlfor the signal that the mixer sends to the amplifier.
In case of a problem or clarification, don't hesitate to post.
Thanks and regards
Please kindly rate this solution
Stelios
Problem with new cdj mixer and decks
no is output level probably is 1.0v need 0,7v output, you need level atenuartor, you may find on audio stores
Korg mini kp only some effects working. Low sound output
I have the same Kaoss Pad mini and have exactly the same problem. I have asked for a solution as well!
The only way I have been able to use live is to turn up master on mixer to compensate, but this is incredibly hard to do if you're not always going through the KP as you have to adjust master volume each time up or down.
I haven't heard any volume problems with the full size Kaoss Pads, think it might just be a KP mini problem.
johnclark
My comp cANT SEE serato scratch live
You have to hook up the SL1 Box or the 57SL mixer and then install the drivers. If you are not hooked up to either of these it will say 'Interface Disconnected' or 'Soundcard Not Found'.
Setting up TTM 57SL, All I hear is control CD
This may seem too simple, but have you tried flipping through your channels on your mixer, or try connecting the wires differently.
2answers
Rane Mixer ttm 54
in sound system you have different sound level start with phono level up to line level up to speaker level.-you will switch to phono when you connect phonograph and you will switch to line when you connect another audio source like dvd and video sound.
Top Rane Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a Rane Computer and Internet Expert? Answer questions, earn points and help others
