you probably need either a new lcd or lcd flex cable - if your under warranty send it in for repair, otherwise it will cost around $35-75 depending on problem
He has added a password to the phone. If he doesn't remember the password you may have to reset the phone if that's possible. Some won't allow a reset without the password or pass phrase.
You will be able to tell the difference when you can remove the storage card and insert it in another device or card reader. Encrypted files will be displayed as .MENC files, with the following filename convention: [filename].[extension].[GUID].menc The [GUID] is the encryption key that determines whether the file can be decrypted on the device where the storage card is inserted. The .menc extension is the indicator that tells whether a file is encrypted. The purpose of the extension is to indicate that you can't open those files. A Lock icon is also associated with the encrypted files. When you insert the storage card back to your device where the files were encrypted, the [GUID] will match with the decryption key on your device and the [GUID].menc extension will not be displayed. Encrypted files will appear just like normal files and they can be opened.
Decrypting files: To
decrypt files that are encrypted, the current solution is to transfer
them from the storage card to a computer via ActiveSync or Windows
Mobile Device Center, and then copy them back to the storage card after
the Storage Card Encryption has been disabled on the device.
To disable Storage Card Encryption:
Go to Start>Settings>System Tab>Encryption.
Uncheck the box that says “Encrypt files placed on the storage card.”
i downloaded the photos from my HTC mobile to my PC, but they could not
be read because they are in MENC format, so i want to convert them to
JPG in my PC. how can i do this
Go to Start, Settings, System, Encryption (or someplace similar) and
uncheck the “Encrypt files when placed on a storage card” box. Now all
NEW files will be in-the-clear, but existing files will still be
encrypted. (Don’t forget to toggle this back when you’re done if you
want to.)
Next, navigate to your File Explorer, then to your Storage Card. Make a
new folder (name it something obvious like “Unencrypted Stuff”). Now,
find whatever files you want to unencrypt and move (or copy) them into
this folder.
You can now pop your storage card out and read them on any other
computer (or on any phone for that matter). You also freed up between
8K and 16K per encrypted file.
I believe it helps. Its easy and workable.
Cheers!!
Get a 3.5mm headphone adapter for your HTC phone. Use the line out to either a little FM transmitter (very fuzzy) or install an FM modulator in your car (better) or, if your car has one, plug directly into the AUX jack of your stereo. Google "htc 3.5mm adapter" for people who sell pre-made adapters.
Here's a fun do-it-yourself project for those of us without AUX jacks. He cuts up an HTC adapter to connect to a microphone and FM modulator so that he can make a home made speakerphone.
