The model of the TV is 55LH40-UA. The model of genie mini is C61-500
SOURCE: hook up
Purchased a rf modulator and hooked in to the tuner out to modulator and from modulator to tv that made everything work
SOURCE: no signal when hooked up with a digital cable box
I had the same problem and had the cable guy out and everything thinking it was my box. I figured it out by myself here is what i did to fix it. I have the vizio 32 inch hooked to an hdmi cable and through the cable box i had the aspect ratio on 1080i and i should have had it on 720p once I switched it I havent had the problem since.
SOURCE: Connecting antenna -- No Signal
Hi Shelly_Eddie,
Here are a couple of things to try:
Is the TV set to antenna or cable? Use the menu settings
Be sure a wire end is not bent outside of connection, i.e. coaxial cable wires sometimes bend or hide back into the sleeve.
Reset the TV and do a channel scan, unplug and see what happens.
Let me know how you make out. Good luck.
Paul
My Website
