Changed spark plugs after throwing a p0307 code. Cleared code. Car drove fine for a month (approx. 500 miles). Car than threw the p301 p305 p306 and p351 codes. Changed cop's from unfaulted cylinders to faulted cylinders and same codes are thrown. Looking for method of troubleshooting without chasing and throwing $$$ into issue.
Po301,305 and 306 codes are cylinder misfire codes and the most common problems for them codes are bad coil packs on them engines.
I would suggest pulling them coil packs and inspecting them very closely for any signs of cracks, build up on the metals and inspect the boots for any signs of white tracking! White tracking is a sign that the boots are failing and allowing fire/spark to jump.
Anytime I replace the spark plugs, I always replace the boots! They are very inexpensive and they too fail often!
Hope this helps.
SOURCE: my car is cutting off
Hi P0305 is misfire in cylinder #5. Please get back to us if you have further query or else please
accept the solution. Thanks for contacting fixya.com
P0306 is misfire in cylinder#6.
P0316 is misfire on start up.
Have the plugs on those 2 cylinders, and the 2 fuel injectors checked, also
check for spark from the coil on those 2 plug wires.
I have a 2004 LS V8
There all bad by now
Replace all the OEM Coils that are left
Hi
