That depends on what you have equipment wise. An combination VHS/DVD player will do it automatically. If you have two different devices, it will depend on the outputs of the VHS player and the inputs of the DVD read/write device. You can do this by playing around but you need to copy not only the video but the sound as well.
Converting VHS to DVD with a DVD recorder is quite easy. You need a DVD recorder, a VHS player and your VHS cassette, an RCA or S-Video cable. For more and you can click into the tutorial.
You need to get a machine that has both and will record dvd. They used to make them years ago, but you could probably find one on ebay or craigs list.
SOURCE: DVD-VR357: Copy multiple vhs tapes to one DVD?
Try using DVD/RW disks with pausing the recording when you change VHS tapes.
SOURCE: Sylvania SRDV495 DVD-VHS
I have the same unit, a SRDv495 and have also been having
a bad time getting dvd's that will work in my machine. I also
bought mine from Sears. I have found one that works every
time and that is a MAXWELL DVD-RW. The trick I think is
the speed of the DVD, so you need to use the ones that have
Up to Max 2X, 4.7 GBgo, 2 Hrs. I find these work every time.
Hope this helps.
SOURCE: recording from vhs to dvd
Direct copy VCR to DVD:
- Insert VHS tape you want to copy
- Insert a recordable DVD disc
- Press DVD copy button on front panel or remote control (to DVD).
- To stop recording press the stop button.
IMPORTANT: If attempting to copy copyrighted material the Samsung DVD-VR320 will detect the encoding and will not allow the copy to be made.
SOURCE: Copy VHS whith copy protection to DVD
hello jordannoanno
this is true the macrovision will stop you copying the copy right tape /dvd .
this can be over come by removing the macrovision >
if you email me i will tell you how to go about this .
riz.
SOURCE: Copy by-pass protection LG RH2T160 DVD Recorder
I already tried googling that and nothing shows up. if there's such code, LG knows it.
