20 Most Recent
Daewoo DV-T8DN VHS VCR Questions & Answers
My VCR is playing too fast
try recording on a blank tape and setting the tape speed to SP (standard play). you should also see options for (LP-long play) and SLP (super long play). I think your machine is stuck on SLP option. if no-go, look for a manual on the web.
I'm trying to transfer VHS
It's an screen display for the Hi-Fi sound playing. However it should only come on when first starting. If it keeps popping up during playback it means that the Hi-Fi sound is dropping out then coming back on. This is often caused by poor tracking or the result of dirt on the video head. Clean the head and see if that solves the problem. If you are doing a lot of tapes keep cleaning it. Few video's have the option to remove on-screen displays. However if they do it will be on the menu somewhere.
My DV-T5DN won't turn on...
your vcr timing is out or mode switch isfaulty.disconect vcr from plug for 20 sec plug back the tape mechanism should reset
No video playback
Maybe the video heads have become clogged. Try using a commercial head cleaning tape to solve the problem.
I would recommend the one that uses the fluid.
Diagrama tv dw19tt daewoo
I think it uses the 150 common chassis motherboard.
https://www.manualslib.com/manual/2480552/Daewoo-Dlt-19w4.html
Daewoo cm905s no audio?
There could be a few potential problems if your Daewoo CM905s isn't making any sound. Make sure all the cables and connections are tight first. If it doesn't work, ensure sure the audio source is not muted and that your speakers are active. Replace the audio source or speakers if the issue is still not fixed.
Help my daewoo start button doesn't work all the rest do what is wrong please .
It is difficult to determine the exact cause of the problem without first inspecting the vehicle. A few possible causes could be a faulty start button, a faulty dashboard control module, a bad ignition switch, or a problem with the wiring around the start button. An auto mechanic should be consulted to diagnose the exact cause of the problem.
My daewoo tv suddenly turn black and power off
the rear of all TV has a sticker label with model.
like xya50zzz123445
50 " TV
yes send it to a shop.
seems the PSU is bad, or overloaded an that takes tests and meters to find. and service manual .both and skills
take it to a shop is always best. or go broke guessing
