Lands Phones Logo
A
Anonymous Posted on Nov 15, 2017
Is there a place to buy just the handset tab for AT&T 950 phone?
3 Related Answers
Muzahura Frank
  • 2071 Answers
  • Posted on Feb 28, 2011
SOURCE: My AT&T 950 phone needs
Well go to this site, they sell most telephone parts, try to search specifically for your model or get intouch with them, they will solve your problem.
regards
Anonymous
  • Posted on Mar 18, 2011
SOURCE: Is there a place to buy just the handset tab for
I have the same problem. Call back and ask for a 2909 handset tab. I think they are the same size. I looked at one last night.
  • 19187 Answers
  • Posted on Feb 06, 2016
SOURCE: Do you have my information? Don't see a place to fill in. Handset tab for at&t 950,,,posibly 2909'tell same Kc8wyp----ok U got it,good luck!
That phone is no longer made, however this part became a head ache for them and they had spares for a while, http://telephones.att.com/
2answers
Does anyone know of a video guide on how to replace a battery in a Beocom 5 phone handset?
Bang & Olufsen Support: This website provides a comprehensive user guide for the Beocom 5 phone handset, which includes instructions on how to replace the battery. You can access the guide by visiting: Beocom 5 - Bang & Olufsen Support (bang-olufsen.com)
1helpful
How do you change the battery on a Bang & Olufsen Beocom 5 handset?
To change the battery on a Bang & Olufsen BeoCom 5 handset, you will need to follow these steps:
  1. Remove the battery cover: On the back of the handset, locate the small rectangular cover at the bottom of the phone. Press down on the cover and slide it downward to remove it.
  2. Remove the battery: Once the cover is off, you will see the battery. Carefully lift it out of the phone by pulling on the small tab at the bottom.
  3. Install the new battery: Take the new battery and insert it into the phone, making sure the contacts on the battery align with the contacts inside the phone.
  4. Replace the battery cover: Carefully snap the battery cover back into place.
  5. Charge the new battery: After installing the new battery, place the handset on the charging base to charge the battery fully.
Note: Be sure to use only the recommended type of battery for your BeoCom 5 handset, and follow all safety precautions when handling and installing the battery.
I need a handset tab for at&t 950 phone.can you help?
Ebay is usually a good place to start, Good Luck :)
KX-TD7696 handsets failing to charge
Most times the connectors are just enough away from contact point. See if you are able to place a flat thin screwdriver to bring the tabs Foward a bit do not over pry as to not break prong. This should work also scrape connectors with same screw driver to bring original copper back
Had to buy a new base for phones and got one phone with new base unit, within phone menus there is a place to Deregister the handset, but I can not locate how to Register the other handsets and nothing...
Hi, If there is not an option for registering the handsets then more than likely it is an automatic function-you may just need to place each handset into the base units cradle to register. Also maybe the base unit has a menu option for registering. I hope this helped, please write back if so and thank you for asking FixYa, Good luck-Prodzilla.
Bought a replacement battery for extra handset and used the adaptor from the base unit to try to charge the battery. This did not work. Charging notice did not appear in the display window and the charge...
:.. extra handset ..." implies you have another handset. Try the battery from that handset in the "extra." If it works, the replacement battery you bought is defective.
Lg vu
User must be logged in as Administrator or have administrator privileges to modify system files
Setting up the handset
1. On the handset, touch the Menu icon located in the lower left corner of the main screen.
2. Touch the Settings icon located on the bottom of the menu tabs.
3. Touch the Bluetooth icon.
4. Touch Turn On.
5. Touch Settings.
6. Touch My Device Visibility.
7. Touch to select On.
8. Touch Set.
Setting up the connection
1. On the PC, double click the My Bluetooth Places icon on the desktop.
2. Click View devices in range.
3. If the handset does not appear, click Search for devices in range.
4. Right click the icon representing the handset and click Pair Device.
5. Type a numerical pin code (example: 1234) in the Bluetooth PIN Code field and then click OK.
6. On the handset, an Accept? prompt will appear, touch Yes.
7. Type the same Bluetooth passcode (Bluetooth PIN Code) entered on the PC and touch OK.
8. On the PC, return to My Bluetooth Places.
9. Right click the icon representing the handset and click Discover Available Services.
10. Double click the Dial-up networking icon.
11. When the connection window opens, click Cancel.
12. Click Start, Settings, Control Panel and double click Phone and Modem Options.
13. Click the Modems tab.
14. Click to select Bluetooth Modem and click Properties.
15. Click the Advanced tab.
16. Type at+cgdcont=1,"IP","isp.cingular" in the Extra initialization commands field.
17. Click OK.
Making the connection
3. Right click the icon representing the handset and click Discover Available Services.
4. Double click the Dial-up networking icon.
5. Type [email protected] in the User name field.
6. Type CINGULAR1 in the Password field.
7. In the Dial field, type *99#.
8. Click Dial.
You will now be connected to the AT&T data service
NOTE: I had to change every instance of "isp" to "wap" for this to work (including the Advanced Settings Tab), but y'all might not have to. Hope this helps.
Top AT&T Lands Phones Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you an AT&T Lands Phone Expert? Answer questions, earn points and help others
