SOURCE: yonan ac split mini 1.5 ton error codes E1
CHECK ROLLOUT SWITCH AND CHECK FOR A POSSIBLE
GROUND FAULT..OR FUSE..
SOURCE: E8 error code
8E - OVER CURRENT ERROR
IPM fault signal (this is caused by the overload of the MICOM INTO during motor action).
IPM: Integrated power module. The IPM controls the motor.
If the fault (low signal) happens to be sensed even once during the washing/rinsing stage, the motor stops immediately. However, during the dehydrating stage the signal is to be sensed, when the number of signals reads more than 6 per 500ms during the Washing or Rinsing cycle action.
If the motor stops working, in one direction ten times, "8E" Error is displayed.
During dehydrating, when the overload is sensed, the motor stops working at once and then feeds back to the initial stage of the dehydration unbalance sensing. When the feed back has occcurred twice, Error "8E" is displayed during the dehydrating unbalance sensing, No error happens by overload sensing. When it happens at more than 800rpm, the process is stopped compulsorily. Power Switch OFF can clear the overload error.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
SOURCE: goodman mini split model # wmh24-1a error code
It's not an error. you have it set in auto mode and it is cooling. when it switches to heat the lights will switch as well. Set to cool only and it should go away.
SOURCE: Ductless mini split heat pump comfort-aire error codes
E:1 room temp. sensor fault. / indoor unit.
see more pls Air Conditioning Fault Codes
SOURCE: panasonic mini split air conditioner css9nkua error code h99 what does it mean
12.11 Freeze Prevention Control 2
• Control start conditions
o During Cooling operation and soft dry operation ? During thermo OFF condition, indoor intake temperature is less than 50°F or ? Compressor stops for freeze prevention control
o Either one of the conditions above occurs 5 times in 60 minutes.
• Control contents
o Operation stops
o Timer LED blinks and "H99" indicated
You may need the assistance of a technician. Service manual located here:
http://www.mcaair.com/docs/panasonicac/CS9NKUA%20CS12NKUA%20Service%20Manual.pdf
