SOURCE: STOPS RUNNING IN MID-CYCLE
Try placing something like a chair with books or heavy objects on it in front of the door. Tip it with objects under the front legs and place objects on its seat until the pressure closes the door and the dishwasher starts. Put additional objects on the seat to insure vibration doesn't make the door pop open. If the cycle completes, the problem is probably the door switch. If not, the problem may be with the timer switch. If it's the timer switch the dishwasher will probably stop at the same position each time.
SOURCE: Dishwasher stops mid cycle
Do the foll. things:
1)Check if there is water on the bottom pan. Remove the panel down on the backside of the machine and look. If it's water there, wipe it well up with a towel or so.
2)if ur dishwasher doesn't starts then:
First, check the usual suspects: Make sure the circuit breaker isn’t tripped and that the wires at dishwasher’s power junction box aren’t burnt. If all that checks out, then go right to the control panel area.
Asko dishwashers have had problems with the wiring in the control panel area burning or melting– very messy. While your problem may not be as dramatic as that, the problem may still be visible. You may find burnt or discolored wire terminals or the spades on the start button switch may be burnt– anything burnt or discolored has to be replaced. You can buy any replacement parts you need right here.
Goodluck,
Dont forget to rate me as fixya..
SOURCE: dishwasher won't stop when door is opened mid-cycle
Welcome
You need a new door latch mechanism.
It is faulty and not doing it's job of over riding when the door is opened
Please remember to leave a solved rating before leaving
SOURCE: door locked light flashing when door is closed
push on the door where the lock is... it may not be fully locked.
