I have a Peavey XR 8600 PA, I have tried adding an external vocal effects module into a mic line but it drops the output signal of the entire PA by about 75%. I have a separate powered monitor I use with that vocal, connected within that mic line and it works great (powered mon. in main vocal line, allows us to have two separate monitor levels using that mon., and then the regular monitor mix from PA to mon.s out of the Main/Monitor connection). However, if I connect the external vocal effects module anywhere in the line (mic-effects-powered mon-to-PA, or mic-powered mon-effects-to-PA, etc.) the output drops by more than half volume. Any ideas on why this is?
Well, I would say it isn't dropping the level of "the whole pa", it is just dropping the level of the input you have plugged the fx into. Check the settings on your fx unit, there are usually input, output and mix controls that are independant of "the pa" and affect the amplitude of the signal going into your mixer from the fx unit.
SOURCE: how to send at same time main mix and alt 3-4 outputs signals
The subwoofer MAY only have a single channel. If so, you would just use either 3 or 4 to the subwoofer.
Normally you would just tap off the main mix. The only reason I can see for using the alts is to have seperate sliders for level control.
SOURCE: how do i connect the cables between peavey vocal
if you mean effects loop try graphic out to ultraverb input and output to power amp in. this will effect all channels of the xr500c
SOURCE: How do i connect 2 monitors to the one monitor
The monitors will have to be POWERED monitors with built in amps.
You can simply use a wye splitter cable to drive the two monitors. Run the cable from the mixer to one monitor and put a wye cable and an extention to the second powered monitor speaker.
Testimonial: "Thanx, just what i wanted"
SOURCE: i have the peavey xr
That's easily done. Simply connect the left(or right) output of your mixer to one of the channels on the peavey. Use any line input. Since the peavey is a mono system, there's no need sending a stereo mix to it.
SOURCE: I have a peavey 8600 powered mixer. If i run
If you run the speakers FROM the main you should have BOTH the effects and the EQ invilved with your signal.
