I fixed it once, however, but it didn't last very long. The switch is stuck in the operating position. Also- I've just taken it apart again to fix it, and when I did a very small part popped out of the switch box. I need a diagram as well to put the little what looks to be a contact point of some kind, back where it belongs. Please help me. Thanx.
SOURCE: automatic gearshift stuck in park
The release for the shifter is tied to the brake lites, check to see if the brake lights work, if they don't then test the brake light switch at the top of the brake pedal, if it lights a test lite when you press the brake it is ok, in that case you need to check the little solenoid that pulls the cable to unlock the shifter, it is bolted to the top of the steering column, in order to get at it you will have to unbolt the column and drop it dow.
SOURCE: i need a wiring diagram for a milwaukee heav duty circular saw
It is probably something like a 6365 and on all the Milwaukee products they have a switch wiring diagram but nothing for the switch. I would recommend going to a local repair center with the switch and match it up with a new one probably less than 15.00 If you give me your location with zip code I can direct you to the closest one. Let me know
SOURCE: Saw runs continuously
The on off switch has a contact that has probably fused together from making and breaking causing an arc. You may try giving it a good 'wrap' with the back of a screw driver to free it, or replace the switch.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
SOURCE: Karcher 3.97M Short cycles after trigger is released.
Dear csdamman,
There is a valve called the spill-valve. It is often called the control valve. This valve activates the micro-switch. When the gun is released, pressure builds up and compresses this spill valve. At the same time it puts off the micro-switch. This will then stop the machine. Now when the spill valve is faulty it cannot hold compreesion under pressure so it starts de-compressing and starts the machine again. This goes on in a cycle as you explained. So you have to change the spill valve. If the spill valve that operates the micro-switch is part of the upper head,...then the whole head must be renewed. Myself I rarely service Spill Valves. The best thing is to renew it. From your explanation it seems that you did not take notice of this Spill-Valve. Infact when you mentioned Pressure Switch, I do not know if you are refering to the spill valve. If you are....then saying that the Pressure Switch moves and operates freely, does not mean that it is OK.
In certain machines in the outlet...there is a small valve, coloured black and red or green and yellow. This sometimes when faulty, it gives the fault you mentioned. Sometimes an inlet valve gives the fault you mentioned. But from my expirience it is most of the time that the Spill-Valve is the fault.
Regards,
Fulltech.
SOURCE: gun wil not trigger after stopping
I'm not real clear on what you're saying, but I think it's that the trigger will not shut down the pressure as it should. It stays stuck on. The other info is how long you've had the washer, but my hunch is that maybe you have hard water, and the deposit build up may be getting the trigger stuck. Try spaying some penetrating oil inside the wand to loosen any deposits that may have built up.
