SOURCE: Register online
I work for Coby technical support. Our customer service phone number is 1-800-727-3592.
Actually, there is no reason for you to register the product. Registration is used for marketing data so that the corporate office's sales and marketing departments understand what type of people are buying the product. This is why most registration cards ask so many questions. As far as your warranty is concerned, the only thing you'll need is a copy of the receipt. Filling out registration cards is just another way companies try to get your information.
If you feel this solution doesn't deserve a good rating, please let me know why so that I may better assist you. If there is anything more I can do to help, I will!
SOURCE: I need a tech sheet for a kenmore refrigerator mod # 50594000 ser
go on searsapplaince site type in your model number and it will bring up a parts list for you unit hope this helps they also have the tech sheets available there also
I will try to locate a wiring diagram for your model ET19RKXFN01 but to change the defrost timer you will only need to know its location. Here is a link to the repair parts=> ET19RKXFN01_Repair_Parts_List
Go to page 5 of the repair parts list and you will see item number 4 Then on page 6 of the parts list you will see the timer part number beside the item 4. That is your defrost timer part number 2193084 Defrost Timer
Your refrigerator is an older model and may have the wiring digram in a packet behind the kick plate in the front near floor. Changing the defrost timer will not require use of a wiring diagram. Simply remove the old timer and replace the new defrost timer by plugging it into the wiring harness. The defrost timer can be found behind the control panel inside the fresh food compartment where the controls are located above the top shelf. If you have questions just let me know, Thanks Sea Breeze
