Boating Logo
p
paul coffey Posted on Oct 03, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Will the minn kota deploy if it is not in the water
Gordon Richard MacLean
Level 2:
Champion:
  • Expert 253 Answers
  • Posted on Oct 04, 2017
Expert
Level 2:
Champion:
Answers
253
Questions
Helped
77510
Points
481
Good Afternoon ,
Yes It Will And It Will Run As Well ,
Its Fine To Test It Out Of The Water .
Be Carefull Of The Proppeller As It Can Cause Serious Injury To A Person If You Are In The Path Of Its Rotation.
You Can Run It For a Short Period As The Water Keeps The Electric Motor Cool.
Hope This Helps
Regards
Gordy
5 Related Answers
Anonymous
  • 10 Answers
  • Posted on May 02, 2009
SOURCE: Where can i get a circuit board for my minn kota
http://www.northlandmarine.com/MinnKotaQuickRef.htm
You need your serial number of the trolling motor, length of shaft, and thrust poundage.
or you could call Minn Kota direct and give them the same information at 800-227-6433.
Anonymous
  • Posted on Jun 04, 2009
SOURCE: How do you program extra Minn Kota® CoPilot Replacement Transmitters?
According to my user manual
To learn the ID number of additional remotes, follow these steps:
1.) Press and hold the LEARN button located on the side of the receiver (receiver will emit a continuous tone). A small blunt object must be used to depress the LEARN button (pen or screwdriver).
1.) Press any button on the remote (receiver will beep 4 times confirming that it has "learned" the ID number of the remote and that the programming is valid and complete).
Anonymous
  • 3 Answers
  • Posted on Jun 13, 2009
SOURCE: year made MKAD2674059 minn kota
According to: http://www.northlandmarine.com/MinnKotaMotorControlBoardAssm.htm
*Note: Newer model trolling motors have serial numbers beginning with the two-letter prefix MK (Minn Kota), followed by a two-letter year code. MKAB .......... 2001
MKAC .......... 2002
MKAD .......... 2003
MKAE .......... 2004
MKAF .......... 2005 MKAG .......... 2006
MKAH .......... 2007
MKAI ............ 2008
MKAJ ........... 2009
MKBA .......... 2010 A serial number with the designation MKAB denotes a
2001-motor and MKBA would be a 2010-year model
Anonymous
  • Posted on Jun 28, 2009
SOURCE: I need Minn Kota Power Drive operators Manual
I'm installing a Minn Kota Power Drive 70# on my Crestliner Fishhawk. I understand the 24 volt system. however the boat has 2 black, an orange and a red wire running to the batteries. I know black to neg. but where do the orange and red wires go.
Anonymous
  • Posted on Jul 13, 2009
SOURCE: i have a minn kota deckhand 35 that wont wind up.
Solution- Take the cover off the Deckhand 35 by Minn Kota. Inside is a motor drive. Remove the cover plate held in place with 4 screws. inside are nylon gears, most likely broken. The gears can be replaced with a Minn-Kota Deckhand Gear Repair Kit.
I found mine on the web at Northland Marine.com it's about $24.00 for the kit, plus shipping.
Good Luck!
Minn kota ultrerra is stuck in stow and will not deploy. How do I reset or troubleshoot?
In the unlikely event Ulterra will not trim or stow, the following procedure will reset the motor and restore functionality:
  1. Press and hold the POWER button located at the mounting base to turn power off (green LED light will turn off).
  2. Press the POWER button until the green LED light illuminates.
  3. Wait 3 seconds.
https://www.minnkotamotors.com/support/faqs/there-manual-over-ride-function-case-power-loss-or-if-auto-stow-and-deploy-does-not
My minn kota works great on dry land but wont work right in the water. It started after I went thru a very hard rain.
I don't know what you mean by it doesn't work right in water. Is the prop spinning correctly in water? If not, check the shear pin, it may be broken. If the motor bogs down, it may need to be dried out more.
Do all Minn kota 112 remote control deploy throlling motor with a touch of a button
Yes the 112 is the best Auto Pilot. You control everything from around your neck. Waypoints last fishing hole. The coolest thing when you go to a big lake and the water fluctuate day today, your waypoints on the remote keep you in the same depths you fished before in that spot and has recorded your fishing hole so all you do is it resume and your trolling motor will guide you through the last way you fished the spot. All you have to do is kickback and hook the fish and hit pause reel the fish in and hit resume and you Auto Pilot will keep you in the same depth of water and on your course you saved last time you fished that hole. Way Cool!, Only saves tracks for 250 yards safety.
Walld"
1helpful
WHO STOCKS A 2991251 CABLE FOR A MINN KOTA
Sherry, I think there may be a new Minn Kota part # . Check the attached links. Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Minn Kota Power Drive Non Auto Pilot Coil Cord Assembly 2991283
Minn Kota Trolling Motor Part COIL CORD STRN RLF PD48 54 2991283
http://minnkota.com.au/wp-content/uploads/2014/07/55-PowerDrive.pdf
Can get replacement parts for my Minn Kota trolling motor FAQs
My minn kota endura 55 is three years old is making a grinding noise when in operation..
I had this problem with my MinnKota Endura 35. The gear teeth that turn the prop are off center and need to be realigned. You need to take it to a service depot as trying to open the casing yourself may do more damage. Plus when it it put back together you need to ensure that it is water tight again.
Cost me around $85 at the local marine mechanic...
2helpful
Got the Endura 30 from my wife for Christmas. Hooked it to the boat,a 12 foot MirroCraft and tested with battery and overall check, looks good so far. First time in the water on Monday, May 24, made it 30...
have you called the dealer or returned to the store your wife bought it from. they should be the ones to warrenty the motor. if she bought it used then you need to buy the necessary parts from a suitable store and move on. minn kota is a good company and they make a good product. i do understand your frustration. you might ask for a manager at minn kota if your wife brought it new and she if you can successfully get a better answer on an appeal. good luck.
Minn Kota e-drive. Hit timber in water. propeller get no power
okay i'm thinking that you need to get a new propeller because if it does not give power in the water then it won't help you if you get stuck
Sep 12, 2009 • Boating
Overheated Minn Kota Endura28
This sounds like a fairly big deal. You need to check it water got into the motor. Turn it upside down and see if water comes out of the handle end of the motor. This may be a shop deal.
Top Minn Kota Boating Experts
ADMIN Andrew
ADMIN Andrew
john h
vince
Are you a Minn Kota Boating Expert? Answer questions, earn points and help others
