SOURCE: technomarine
Sounds like the main drive is not "engaged" or you are in "stop watch" mode. Check to make sure you are in the correct mode. Then check to see if you can change the hour/minute hands. Reset the time and re-engage. See if that corrects the problem. (You've probably have done this already)
The watch has a 2 year warentee plus because it's water resistant down to 330 feet, I would take it back or to an authorized dealer to have it repaired. Other wise you stand the chance of damaging as really nice watch. And while you are there have them explain all the features. Really is a nice watch.
SOURCE: technomarine watch battery replacement
If you plan on doing this yourself, find a nice heavy pair of needle nose pliers and put the ends in the knotches on the casing back. Have them as far apart from each other as you can and turn counter-clockwise. If you still have problems opening, put the watch in a vise with the lugs in the teeth of the vise. DO NOT tighten too hard or you will snap the lugs. It dosn't have to be tight , just enough to hold the watch while you turn the back. If you still have problems please let me know and we will find another way of doing this.Good luck!!
SOURCE: how much the technoMarine watches?...
Link
Normal
0
false
false
false
MicrosoftInternetExplorer4
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-parent:"";
mso-padding-alt:0in 5.4pt 0in 5.4pt;
mso-para-margin:0in;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:"Times New Roman";
mso-ansi-language:#0400;
mso-fareast-language:#0400;
mso-bidi-language:#0400;}
Hi Guest,
Please feel free to browse the above link for the price of technomarine watches.
Thank you.
