I suggest you can approach Theunlockarena.com and specify the country,locked network of Huawei Y530 .Based on the availability you can get the permanent unlock service along with free instructions.
SOURCE: How do you update HUAWEI Y530-U051 Mobile
It depends on where you live, and who your telcom is. A general rule of thumb is that if it aint broke, don't fix it. In other words, you can't undo a firmware upgrade in most cases. But if you must upgrade, I would urge you to do some research into the firmware before loading it on your device. Here's a link to get you started. Good luck
SOURCE: Hi i would like to know if anyone can help me unlock my phone for free its HUAWEI Y530
There is four simple step to format . just follow it.
remember if ur phone memory have important data so u should be aware that i will erase ur data.but there is no other methods so..
1-
Power down your device. Before you begin the reset procedure, you will need to completely power your device off. If it is frozen, you can pull the battery out to turn it off.
2-
Press and hold the recovery buttons. The buttons vary from device to device, so you may need to look up the instructions for your particular phone. You will need to press and hold the buttons for a few seconds. Some of the more common button combinations include:
Wait for the restore process to compete. After your phone resets, it will be set back to factory defaults and will be like it just came out of the box.
SOURCE: Please I want the unlocked network code of huawei y530
use this software, it very easy (use only cracked):
DC-UNLOCKER 2 Client 1.00.0460
maybe find in this page: http://gamerider24.blogspot.com/2014/08/dc-unlocker-client-final-version-download.html
this is tutorial (maybe and link):
www.youtube.com/watch?v=SsFvnBWOq6A
