Need help if anyone knows the default password for web login admin please.. thanks
SOURCE: i forgot admin.password...plz help "windows XP version 5.1"E-machine
YOU CAN CREATE ANOTHER ADMIN ACCOUNT USING DOS MODE....
SOURCE: Recover admin name and password
If you want to reset the Linksys router username and password, you just need to press and hold the reset button of the router for 15 seconds using a pen while the power is On, and then after that turn off the power of the router for 5 seconds and it will be back to its defaulkt settings with default password admin and no username...
SOURCE: forgotten administrator account password!
download this file burn it to a cd and boot from it.....select the directory whr your windows is installed
http://rapidshare.com/files/226200662/cd080802.zip
SOURCE: How to Unlock Windows Vista Password?
I would like to introduce "Windows Login Recovery". It not only supports XP, 2000, and NT, I have personally tested it with Vista Home Premium and Ultimate. It works perfectly to reset any local user account to a blank password. I Wrote it to an old 128mb USB flash drive to recover windows password. Booting up and clearing a password takes a minute or two works like a charm. You can download it from http://www.windowsloginrecovery.com
SOURCE: forgotten administrator password of windows XP
For reset Windows Xp admin password,there are about three methods :
1.Use the built-in administrator account which you can logon without password in safe mode.It was built when you install your system and its password default as blank.Press ctrl+alt+delete twice in the welcome screen and you can see a classical logon dialog box,type administrator and press Enter.Or you can press F8 when you start/restart your computer to select start from safe mode.
2.Use a password reset disk If you have created ever.Of course it must be created for your current password.You can find a prompt when you input a false password in the welcome screen.Clik it and follow the guide.
3.If the two methods above cannot help you,you can find a recovery tool.As far as I know, there are many password tools on the network, but I have used is "Windows password rescuer professional 3.0" ,it is simple and safe that the average person will use it. It can soon reset the password in several minutes.Only four steps can help you reset the lost Windows password:
Step 1: Download Windows Password Rescuer and install it to another computer.
http://www.bestvistadownloads.com/software/t-free-windows-password-rescuer-advanced-download-smceigwe.html
Step 2: Run it and burn it to a bootable CD/DVD or USB flash drive.Before this confirm that you have insert a CD/DVD or USB.
Step 3: BIOS setting:Setup your own computer boot from CD or USB.Press F2 or DELETE when you start/restart your PC to get into the BIOS SETUP list.Use arrow keys to select boot manu,and use +/- key to move the CD/DVD or USB option to the first site.Then inset the CD/DVD or USB you have just created. Press F10 to save and exit.
Step 4: Reset Windows password: Wait for a moment,it will display friendly operate window,and you can reset whichever password on it.More detailed instruction refer to this article:How to recover windows xp/7/vista password.
