Boating Logo
B
Bill Hogrebe Posted on Jul 01, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
2004 60hp efi Johnson outboard is not charging. How do I trouble shoot stator?
Steve P
Level 3:
  • Johnson Master 3,912 Answers
  • Posted on Jul 02, 2017
Steve P
Johnson Master
Level 3:
Answers
3912
Questions
5
Helped
1307966
Points
15904
1helpful
2answers
1957 johnson outboard 10 hp fuel mixture ratio
https://www.google.com/search?q=1957+johnson+outboard+10+hp+fuel+oil+ratio
What is the mix ratio for a Johnson outboard motor?
Any Johnson outboard motor built since 1964 requires a 50/1 fuel ratio. Motors built prior to that date require a 32/1 ratio, with the exception of a few fishing motors built prior to 1955 that use a 16/1 ratio.
Feb. 22, 2021
What is the mixing ratio for a Johnson outboard motor? - Mvorganizing.org
Stator wiring on 48 HP Johnson outboard
Hey Troy, get one of these... sounds like you might need it,,,they are invaluable!!
Johnson Evinrude Manuals 1917 2007
Replace stator on 1987 johnson 48hp outboard
Take off flywheel and replace
Oct 12, 2014 • Boating
1helpful
Charging stator wiring diagram /1981 .25 hp johnson ng
SELOC REPAIR MANUAL WWW.OVERTONS.COM OR WWW. WESTMARINE.COM
Jul 26, 2013 • Boating
3answers
How do i replace the water pump in a 2005 150 hp evinrude outboard motor
Take the cowling off. Also drop the foot. There wil be a stainless linkage rod that runs the length of the motor that you will have undo to drop the foot. The water impeller will be inside a stainless casing that you will have to disassemble.
Aug 17, 2012 • Boating
2answers
I have no spark on 1989 7.5 evinrude outboard motor
Hi have you tried it with the stop switchl/button disconnected, if so you have only got the stator under the flywheel left to replace, regards Phil.
Jun 04, 2012 • Boating
1helpful
Does a 1977 Evinrude 70 horsepower engine hav a charging system?
The 70s Johnson or Evinrude outboards of similar sizes did not have any charging system. I had an old Johnson 50HP (key injection) mounted on an 18Ft Zodiac and I needed to remove and recharge the battery once every couple of weeks. Keep the battery dry and the contacts well greased.
1helpful
Charging system not working
http://www.crowleymarine.com/brp_parts/diagrams/38308.cfm
start here..Need Year?
Top Johnson Boating Experts
NOEL
NOEL
jws1013
Are you a Johnson Boating Expert? Answer questions, earn points and help others
