Measuring Tools & Sensors Logo
A
Anonymous Posted on Jun 23, 2017
Sp5 laser level do not work.L oaned it to neighbor and got it back not working.How to fix?
Marvin
Level 3:
Top Expert:
  • Laser Master 85,242 Answers
  • Posted on Jun 23, 2017
Marvin
Laser Master
Level 3:
Top Expert:
Answers
85242
Questions
28
Helped
29060142
Points
266281
You don't fix these, no parts to do so are available.
Sc556
To reset fuser SC codes you need to enter Service Programme Mode and reset SP5-810 to 1, then turn the main switch off and on again. If you need help on entering SP mode etc. then take a look here.
Ideal #35-207 how to get it to work
Here is a page capture from the manual of the operation of your laser level/ Hope this helps. (highligt and copy to a viewing program like MSPaint in order to zoom in)
2answers
Vertical laser is no longer working.
Had the same problem. Actually had vertical beam and one horizontal beam not working. I put the laser in the freezer for about 30 minutes, took it out and all the beams work. Prior to that I cleaned all the battery contacts and of course installed fresh batteries all to no avail. I have no idea freezing it worked but it did. Of course freezing it would cause condensation to form on the inside of the instrument but why that would make the laser work is not known. I hope it works for you.
Jim from Fredonia.
Just wondering if the stanley SP5 5 beam laser level can be used oudoors.
Yes but i don't recommend it the light has to be perfect, in order to see the beam.
3helpful
2answers
SC 541
Take the fuser out and clean under the thermistors, and reset the code by entering test mode ( turn off printer hold down online and escape as you turn on printer selece 2 engine go to sp5-810 and reset this.
-Carl, please let me know if this helps.
13helpful
3answers
Ricoh 1515 MF shows error code sc542
Um.. I don't see an "online" or "escape" button anywhere on the printer...
Imate SP5 sim/phone problem
Even though I have no tech experience, I figured it must be a setting problem between the phone and my simcard but could not work out how to resolve it. I eventually solved the problem myself by doing a factory default reset. Lost a couple of downloads but so what ! It works now and I'm happy!
2answers
Took out my amp and sub put it back in and now it wont work
you masht seting all parameter too the midel befour selected oan by oan,step by step equalayzer
Top Laser Measuring Tools & Sensors Experts
NOEL
NOEL
ADMIN Andrew
ADMIN Andrew
Dave Parker
Dave Parker
Level 1 Expert
Are you a Laser Measuring Tool and Sensor Expert? Answer questions, earn points and help others
