Can anyone tell me what the problem might be with my samsung rear projection tv?red light goes flash for a few minutes then the red light stays on but the tv dont switch on
MY philips tv model number 55PL9773/17 WAS TURNING OFF THE SCREEN AND LEAVING THE AUDIO ON FOR ONE MINUTE. THEN THE YELLOW LIGHT STAYED ON. THEN THE LIGHT TURNED OFF. thEN I TURNED ON WITH THE REMOTE AND THE YELLOW LIGHT TURNED ON AND A FEW SECONDS LATER CHANGED TO THE GREEN LIGHT AND THE TV TURNED ON. AFTER A FEW MINUTES, BETWEEN 10 AND 30 IT DID THE SAME THING. NOW IT IS OFF WITH A BLINKING RED LIGHT PERMANENTLY ON. TO TURN IT OFF I HAVE TO UNPLUG IT FROM THE WALL. I REPLACE THE LAMP A FEW WEEKS AGO AND IT IS FINE.
The flashing LED may be telling you the source of the problem; note the relative spacing of the flashes and the number of times it flashes before staying off.
The set is trying to tell you where it is sick but I suspect it is related to the power supply; the most common failure point of most modern sets.
If you post back here as a 'comment' you won't have to repeat your symptoms.
If the lamp has been replaced I would think the Lamp ballast would be most likliest followed by the color wheel and then the Digital board. You can get any part needed for your model at www.tvrepairworld.com just leave them a email they respond quickly.
How many times Red Lamp flashes, its important as it shows problem and its location in tv. Below is detail of lamp blinks and you may know the problem area in tv by counting lamp flashes.
or a new lamp. you could first replace the lamp. the screen might work fine for a couple of seconds, but then it fades away or deteriorates. This means the lamp is going bad.
