Computers & Internet Logo
Second hand zte blade v7 lite and i cant get past the google account verification. I have tried resetting to factory settings but it keeps saying that i need to enter the last owners google account
5 Related Answers
Anonymous
  • Posted on Aug 24, 2009
SOURCE: code to reset factory settings for zte a201
CAN I PLEASE GET MY PASSWORD TO RESTORE MY FACTORY SETTINGS OF THE ZTE A201.
Austen
  • 40 Answers
  • Posted on Jun 24, 2012
SOURCE: how do i reset my laptop to factory settings
What OS are you having?
Reset windows password as following instruction :
On XP you can try this:
Boot computer and press Ctrl+Alt+Delete twice when you See Windows welcome screen / login screen. It'll show classic login box. Now type "Administrator" (without quotes) in username field and leave password field blank, press Enter and you should be able to login Windows.
Now you can reset your account password from "Control Panel -> User Accounts".
On Win 7 or Vista:
Ctrl+Alt+Delete won't work, you have to use some windows password recovery software. I recommend Windows Password Reset .
bronk50
Brian Sullivan
  • 27725 Answers
  • Posted on Sep 11, 2012
SOURCE: tried to reset to factory setting now computer says it cant restore
Restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer
If done properly the user should get to a screen similar to the below screen.
Select the option for Safe mode command prompt only
Windows Advanced Options Menu
Please select an option:
Safe Mode
Safe Mode with Networking
Safe Mode with Command Prompt
Enable Boot Logging
Enable VGA mode
Last Known Good Configuration (your most recent settings that worked)
Directory Services Restore Mode (Windows domain controllers only)
Debugging Mode
Start Windows Normally
Reboot
Return to OS Choices Menu
Use the up and down arrow keys to move the highlight to your choice.
select safe mode with command prompt then type in chkdsk/f/r which will scan for and and attempt repair of bad files and bad sectors on hard drive
you should have no input while chkdsk utility is in progress any input might further damage your computer or
Use the System File Checker tool (SFC.exe) to determine which file is causing the issue and then replace the file.
Type the following command and then press ENTER: sfc /scannow The sfc /scannow command scans all protected system files and replaces incorrect versions with correct Microsoft versions.
hope this helps
christhonny
chris
  • 6 Answers
  • Posted on Dec 16, 2014
SOURCE: how do i unlock my phone
set pawed
Danny Kuhlmann
  • 1443 Answers
  • Posted on Nov 28, 2015
SOURCE: Google lock
Hello,go here for help:
Synchronization issues
How can I bypass the google account verification in a ZTE Blade A110 cell phone?
https://www.unlockunit.com/blog/bypass-google-account-verification-factory-reset-protection/
  • Reset the phone and power it back on
  • Choose your preferred language, then tap on Start
  • Connect the phone to a Wifi Network (preferably your Home network)
  • Skip several steps of the setup until you reach the Verify Account screen
  • Tap on the email field, in order to activate the keyboard
  • Most ZTE phones come with the Swift Key keyboard, so you need to tap on the keyboard's menu key.
  • Select Settings from the menu
  • From the Settings menu within SwiftKey select Languages
  • Minimize the menu on the screen, then go to the Google search bar
  • When prompted to sign in with a Google Account, choose "No, Thanks"
  • In the Google search bar, type "Settings" and select it. If the SwiftKey menu pops up again, tap on Got it, then Not Now.
  • From the Settings menu select Backup and Reset
  • From this submenu, choose Factory Data Reset. Go through the entire process and reset your handset again. However, this time you won't see the FRP lock.
2answers
How to bypass google account on zte blade a112lte with a older os i think as all tutorials i have found dont work. I had to reset my phone due to a network error. I have done a back up to my sd card.
Googles' Factory Reset Protection FRP
Googles' Account Verification
Googles' 72Hour Lockout Security
When Hard Reset (with phone Off) Or
Factory Reset (through settings menu) is Performed on any Google accessible smart phone, while User Account is Logged in to phone, and AlSo With Account Recovery Active, Then Google Requires "LOGIN WITH ORIGINAL USER ACCOUNT PASSWORD"
But Then You Dont Remember PASSWORD OR GMAIL.
Ouch......Bummer
No One Wants to Be LOCKOUT of there phone,
HOW TO GET PASSED
GOOGLE FACTORY RESET PROTECTION
ACCOUNT VERIFICATION and 72 HOUR LOCKOUT
  1. On your phone, On the ENTER Account SignIN Page. There is an option to CHANGE PASSWORD.
  2. IF You Have Already Tryed This, GOOD.
  3. YOU ARE One step ahead.
  4. CLICK CHANGE PASSWORD
  5. CAN YOU REmember recovery Email or Number?
  6. You will Be sent "VERIFY CHANGE PASSWORD" email or text.
  7. Were You Able To Change Password?
  8. IF YES, Awsome. DO NOT FORGET NEW PASSWORD skip to step # 18.
  9. IF NO, YOU were Not able to change password.
  10. IF NO YOU were Not able to access Verification email
  11. There is Three Options you have to Unlock Your Phone.
  12. ONE.......TAKE 40$-60$ AND YOUR ZTE to a Mobile Phone Repair Shop.(Boost Mobile Repair, 40$ 2hrs unlock all passwords, you have access to your phone) ***This Option Worked For You, Congradulations!!!!***
  13. TWO.......You can do the same thing the Phone Repair Shop Does at Home, There are a Few Things You Will Need.
  14. ACCESS TO A Personal Computer (Laptop, Friends Computer, Moms Computer will work Too. *(*NO PUBLIC COMPUTER, LIBRARY COMPUTER CAFE*)*
  15. MICRO USB FLASH DRIVE. Is a regular flash drive, 1GB is More than enough empty space. ?MICRO? is two way Cord that allows USB Flash Drive To Also Connect To Smart Phone, Using Charge Input Jack.
  16. Download ZTE LTE Software, directly to Flash Drive.
  17. On ENTER account info page, Connect Flash Drive to Cell Phone. At top of screen, Notification promped askes "Open USB", Open USB>file folder>downloads> zip file>install>download>programs>unlocks phone.
  18. Three.......SKIP TO STEP #30
  19. You were able to Access Verification email. And you still remember password. AWSOME....GOOD JOB.....
  20. This is the simplist way to bypass Google Account VERIFICATION.
  21. So now you are wondering why then new password is not working?
  22. Google also has a 72 HOUR LOCKOUT SECURITY. On the verification Email there is a Time Stamped. The time is your email recieved time.
  23. This time Started Googles' 72 Hour CountDown.
  24. Do not attempt to reset Password, or login again untill countdown has expired. You dont want to chance time Restarting.
  25. If time stamped was 8AM 26th, 72 Hrs is up 8AM 29th. I would wait just a half hour more.
  26. Best thing to do now is Kickback 3 days.
  27. When Countdown has expired, New password will work to log in.
UNABLE TO ACCESS VERIFICATION EMAIL???
NOT GOING TO WAIT 72 HOURS???
NO $$ FOR MOBILE PHONE REPAIR SHOP???
TRY THESE SIMPLE STEPS.
After the phone has finished its factory reset it will reboot and you will be prompted to choose the desired display language.
After choosing the correct language please follow the next steps:
  1. Connect the phone to a Wifi Network (preferably your Home network)
  2. The next screen will ask you for the Google Account
  3. Tap the text field in which the account should be inserted until the Keyboard comes up
  4. Tap and hold the "@" character until a Settings menu pops up
  5. Select Google Keyboard Settings
  6. Tap on the 3 dots in the top part of the screen (or More depending on what Android OS you are running)
  7. Select the Help & Feedback item and select any item in the list that will follow
  8. Long press to select anytext on this page and click on Websearch in the upper right corner
  9. A search field will be shown (delete the text inside the search field)
  10. Type Settings in the search field
  11. Tap "About Phone" and tap 7 times on the Build Number to enable Developer Options
  12. Return to the previous menu and open the Developer Option that just appeared
  13. Allow OEM Unlocking and tap Back two times
  14. Restart the device
  15. Connect it to Wifi again
  16. Notice how you won't be prompted to log in the previous Google Account and instead the phone will ask you to ADD a new Google Account.
Jos
?'s & Commentz.....
Top Google Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
ADMIN Andrew
ADMIN Andrew
Kolbrun...
Are you a Google Computer and Internet Expert? Answer questions, earn points and help others
